Old 10-22-2014, 02:39 PM   #1
Dj_Aquarius
Equinox Lights and Sound
Dj_Aquarius's Avatar
e46 Reset Tool
i found some helpfull Tips & DIY to fixed my problem on my passenger airbag issue, im planning to do it this week and what i understand is i need to have the reset tool, so my question is what is the best or decent reset tool to buy that is not too expensive. thanks in advance. or if anyone can do that for me
Dj_Aquarius is offline   Reply With Quote
Old 10-22-2014, 02:42 PM   #2
bokan
I can reset it for you, I am located in Etobicoke
bokan is offline   Reply With Quote
Old 10-22-2014, 03:07 PM   #3
Dj_Aquarius
Thanks Bokan, i will contact you as soon i fixed the resistor...
Old 10-22-2014, 07:32 PM   #4
windwagen
windwagen's Avatar
I bought 2 different resisters off eBay for that. The light goes out, but it shows no passenger. I wonder if yours will work better.
E39 M5 - for Sunny Days
Old 10-22-2014, 07:41 PM   #5
bokan
resistor has to make airbag active all the time and turn the light off.
Old 10-22-2014, 07:43 PM   #6
Dj_Aquarius
Reset Tool
Hey windwagen, i didnt have the resistor done yet, how many ohms of resistor
did you used? for what i read on the thread 4k7 resistor and diode 1N4007
Old 10-22-2014, 07:45 PM   #7
Dj_Aquarius
@ bokan, that it was supposed to be right? "active all the time"
Old 10-23-2014, 08:57 PM   #8
windwagen
windwagen's Avatar
I never checked - I just bought some "fix" from eBay - two in fact. Whatever I got isn't right. If someone can provide that info, I'd like to correct mine. I still have two of these things, you're welcome to come try it if you wish. I was going to test it on my M5 but never got around to it.... I'm curious how it behaves on a different car - I guess i'll try it this weekend...on the M5.
Btw - I'll give you one - so you can use the connector - in exchange for info on the correct resistor value so I can fix the second one.
Old 10-23-2014, 09:06 PM   #9
Dj_Aquarius
Sure i will try this week and make some and will give you one as well, i hope it will work for us.
i'm trying to make this one from youtube:
https://www.youtube.com/watch?v=x2UqGJ_LK3Y
Old 10-23-2014, 11:11 PM   #10
windwagen
windwagen's Avatar
Hmmmm - I went to get one of the eBay ones.... definitely not wired the same. There is a diode and ONE resistor. Both wired in parallel. I'll get another resistor and fix the circuit.
Old 10-28-2014, 12:01 AM   #11
windwagen
windwagen's Avatar
Update - my FLEA Bay kits are crap. The resistor is 2000 ohm, not to mention it being wired in parallel. I changed the wiring to series and used two 100 ohm resistors as suggested in DJ Aquarius's link and it works perfect. I confirmed it says "Seat occupied".
Thanks for the tip!!!
Old 10-28-2014, 09:18 AM   #12
Dj_Aquarius
windwagen..... sharing is caring
Glad that it works 100 % for you
Old 10-29-2014, 11:20 AM   #13
Linz323
Just in case you're not aware, though likely not directly related to your issue / post-- there is a recall for most E46 airbag units.
Linz323 is offline   Reply With Quote
Old 11-09-2014, 10:13 PM   #14
windwagen
windwagen's Avatar
Hey DJ Aquarius - how did you make out? Everything OK?
Old 11-10-2014, 12:54 AM   #15
Dj_Aquarius
i did the same way on the video but i guess i have to do the reset...
my Brother receive a letter from BMW about the Airbag recall for this car so i guess i will call them to make appointment to get it fix...
but still want to do the reset to find out if i did it right.
