Old 12-04-2005, 07:11 PM   #1
Woofer
Woofer's Avatar
gas/fuel gauge
I have a problem with my fuel guage and i can't figure out what it could be. I have tryed 3 different sending units and the same problem. The fuel gauge is always pointing to full and never decreases from the full spot. If its not the sending unit what else could it be? maybe the gauge it self isn't working properly? I want to get this fixed soon because its a hassel to always guess when the car needs gas. When the gas is really low the warning light does come on though. Anyways any suggestions would be great. for the record all the other gauges work. thanks guys
Old 12-14-2005, 02:09 PM   #2
duenorf
Bad earth on the gauge. Pull cluster, remove nut and washer holding the gas gauge, (this serves as the earth connection) clean then up and reassemble.
duenorf is offline   Reply With Quote
Old 12-14-2005, 02:16 PM   #3
E30 Girl
E30 Girl's Avatar
Send a message via MSN to E30 Girl
I have the same problem and tryed the sending unit and the ground on the guage and both did nothing. Someone told me that it is a bad board on the cluster. You might want to pm Eurostyle he might be able to help you. Hope that helps.
E30 Girl is offline   Reply With Quote
Old 12-14-2005, 02:17 PM   #4
I can get you a gauge for $25.
Edit: i can get both of you gauges! lol
Old 12-14-2005, 03:04 PM   #5
chromius
chromius's Avatar
My gas guage has been flaky for a while now, I find it just as easy to go by KM's. I just reset my trip meter every time I fill up.
Old 12-14-2005, 04:30 PM   #6
new e30 giving you trouble already?
Old 12-16-2005, 01:25 PM   #7
SebSter
SebSter's Avatar
We had Terry's cluster out a few months back and tried everything to fix that.. .even tried swapping my cluster in.. his cluster is fine, it has to be something from the sending unit.
Oh and dude sorry for not calling you, it didnt save your number and i just got home now I was in Niagara and then Orrilia till yesterday night.. I found the link http://www.e30zone.co.uk/modules.php...=techhella.htm
you're gonna have to register to the site (free though)
Old car 1990 325ix. Current car 2000 540i.
SebSter is offline   Reply With Quote
Old 12-16-2005, 01:50 PM   #8
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Likely the wiring if you know both ends work. Have fun electrical gremlins suck.
Old 12-16-2005, 02:41 PM   #9
arsevader
What year e30 is it? The later models have 2 sending units, one for the gauge, one for the light.
James
Old 12-18-2005, 08:04 PM   #10
Woofer
Woofer's Avatar
it;s a 90....where is the other sending uint? i never new that there was 2 of them in the newer e30 models.
Old 12-19-2005, 01:31 AM   #11
arsevader
At least on the m20 models there is.
One sending unit is attached to the fuel pump as in the earlier models, the other one is on the other side of the fuel tank. If you remove the seat to access the fuel pump there is another access panel on the other side.
I can't remember which one controls the light and which one is the gauge.
James
