Old 03-08-2016, 06:14 PM   #1591
Three3seven
Go with the 16x8 all around then. 205/50/16, 215/45/16, or 205/45/16 will all work fine.
Thank you! I think I'll go with 205/45. Would 205/40/16 be ok or does it look funny?
Three3seven is offline   Reply With Quote
Old 03-10-2016, 02:01 PM   #1592
Looks very funny.
Old 03-26-2016, 01:23 AM   #1593
deity
Yo Mystikal
Changed my mind on the work wheels, going for the ccw lm20s with the brushed steel face look imo looks 10 folds better. Can i still run 16x8 f 16x9 r +20 offset or different story ?
deity is offline   Reply With Quote
Old 04-01-2016, 04:50 PM   #1594
Same.
Old 04-02-2016, 03:06 AM   #1595
deity
Thanks champ!
Old 04-06-2016, 04:05 PM   #1596
dilly_e30
If I wanted to run 16x8 et15 up front and 16x9 et18 in the rear, with 5mm spacer up front and 8mm in the rear would I sit relatively flush? If not what spacers should I go with? Also what tire size would you suggest for a little stretch at those sizes? Thanks.
dilly_e30 is offline   Reply With Quote
Old 04-07-2016, 05:14 PM   #1597
Those offsets are so close to perfect that I wouldn't put any spacers on. You will very likely have vibration issues with a 5/8 setup anyway (no lip for the wheel to sit on, very difficult to center the wheel). 205/45 front 215/45 rear would be ideal.
Old 04-11-2016, 07:44 AM   #1598
reubencanyon
Got a 91 318i 4dr wanting to get a set of bbs RF 320s that are 16x7 +42 with 225/45/16 Dunlop starspecs all around. How much of a spacer will I need to get a good semiflush fit. This car will be autoxed regularly. New to the e30 game. Thanks for an help or suggestions!!!
reubencanyon is offline   Reply With Quote
Old 04-11-2016, 07:48 AM   #1599
reubencanyon
Also what is basically the widest wheel/tire combo you can go with on an e30 with rolled/pulled fenders
Old 04-11-2016, 11:36 AM   #1600
I'd go 15mm front 20mm rear.
Old 04-11-2016, 11:37 AM   #1601
17x8 +25 245/35/17
Old 04-11-2016, 01:34 PM   #1602
reubencanyon
Thanks for the info!
Old 04-19-2016, 06:11 PM   #1603
McWattersJ
Early Vert
Hey I am looking at 15" 8.5 with et17.. I believe the bore is 73.1.
i was thinking 215-225/50's on my early model Vert with stock suspension. I like the poke look so if possible I would push them out more.
Yes I am a newb. Any thoughts? advice?
cheers Canucks
McWattersJ is offline   Reply With Quote
Old 04-20-2016, 12:58 PM   #1604
Heh, just answered you on R3V
Old 04-21-2016, 05:16 PM   #1605
Jimmy85'e30
fitment
I have a 1987 325is on H&R Racesprings. I just got 4 20mm 5 lug adapters and some 17inch syle 5s. I havent rolled the fenders yet... Can I even run the Wheels before i roll the fenders? Anyways what size tire do I need to get these wheels on my car...!!! Thanks so much in advance!
Jimmy85'e30 is offline   Reply With Quote
