Old 07-04-2005, 04:39 PM   #1
Justin e36
Justin e36's Avatar
exhaust question
quick question clarification.
I understand the 318 / 320's have a single pipe, single tip from the engine back.
the 325's I'm not so sure... are they single pipe with a dual tip on the muffler?
I also understand that 328 / M3 has dual pipe, dual tip.
Please clarify... I'm half done a new exhaust, and now I'm wondering if I'd have to re-do it again if I end up putting the 325 engine in.
Old 07-04-2005, 05:00 PM   #2
rico328i
exhaust
HEy Justin,
I can only comment on the 328/M3 exhaust. Yes, you're right. 2 pipes all the way back and 2 tips after the muffler. Remember though, the 328's have this odd 'butterfly' valve that actuates only at high or full throttle. You can see it from the passenger side tip I believe.
Hope this helps.
Old 07-04-2005, 07:10 PM   #3
duffy325
Justin
The 325i has the same setup as the 328/M3. Dual pipe up to the cats and beyond. The exhausts for the 325i/328/M3 are all interchangeable.
Someone else can verify this but I am 100% certain.
duffy325 is offline   Reply With Quote
Old 07-04-2005, 07:24 PM   #4
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
on my 93 318is I have 2 header pipes come into a Y pipe
then it's single pipe all the way back to the single tip exhaust.
Old 07-04-2005, 10:36 PM   #5
app
my 325i is dual all the way
Luke
92' 325i
app is offline   Reply With Quote
Old 07-04-2005, 10:41 PM   #6
Justin e36
Justin e36's Avatar
bmd... really! I'd have to check that... you could be right.. could be a Y under there, maybe I can run 2 pipes now... my engine would be hideous without backpressure till I drop the 325 in there though.
thanks!
