Old 05-28-2008, 11:14 PM   #1
mousecrab
experience with run flat?
heard and read quit a bit of negative things about run flat. Are they really bad?
heard they leak easily and are hard to fix, also heavier than normal and wear out much faster...
mousecrab is offline   Reply With Quote
Old 06-13-2008, 09:43 AM   #2
Blades
Your opinion is to long
Blades's Avatar
If you want to feel every single bump and rock on the road then go for it. Its usually for moron women that get flat tires a lot. I see bmw now sells it with there winter package or something like that.
-=[ BL/\DES ]=-
Old 06-15-2008, 09:24 PM   #3
skru_fase
Lurker
skru_fase's Avatar
a friend has them on his 645 and hates them... as was said above, you feel every bump, and they are expensive as hell to replace.
skru_fase is offline   Reply With Quote
