Old 01-24-2007, 07:00 PM   #1
Ant118
BmwAviator
Ant118's Avatar
M Parallel's on E36 M3
Is it possible to fit the 7 series staggered M Parallel's on a E36 M3. Also do i have to get the Replica M Parallel's and what offset. Thanks
Anthony
1997 Estoril Blue ///M3 - Track Car
2011 Alpine/Black 335is
Ant118 is offline   Reply With Quote
Old 01-24-2007, 07:13 PM   #2
shimajer
loudddddd
you have to get the replicas, the OEM ones for 7 series won't fit onto your car
shimajer is offline   Reply With Quote
Old 01-24-2007, 07:15 PM   #3
Ant118
BmwAviator
Ant118's Avatar
^^ Thanks,
Also on a 8" rim what is the best tire, can i run 235?
Old 01-24-2007, 09:28 PM   #4
///Milan
///Milan's Avatar
Don't even worry about it, I'm buying those wheels Ant.
///Milan is offline   Reply With Quote
Old 01-24-2007, 11:59 PM   #5
yes, 235/40/18's will fit fine
Old 01-30-2007, 07:11 AM   #6
NOTORIOUS VR
NOTORIOUS VR's Avatar
I'm pretty sure that w/ the right spacer you can get the rims to fit just fne
Old 01-30-2007, 08:39 AM   #7
A.K.A. Blackout
BLACKOUT
A.K.A. Blackout's Avatar
I am running 225 40 18's and I get a little rub over big bumps. Then again, my car is pretty low right now.
A.K.A. Blackout
A.K.A. Blackout is offline   Reply With Quote
Old 01-30-2007, 11:40 AM   #8
Gamite
Gamite's Avatar
spacers will make it worse. The offset is too low for E36.
www.gamite.net
Old 02-12-2007, 10:29 AM   #9
uber e36
uber e36's Avatar
What about shaving the inside of the wheel's hub?
'95 325is
?02 C4S
Old 02-12-2007, 03:16 PM   #10
TheMadChigga
TheMadChigga's Avatar
depends how much to shave, and then you might have problems with the spokes hitting the calipers.
