Old 08-26-2008, 04:07 PM   #1
Nascar318is
Nascar318is's Avatar
Need Your Help Boys.
I'm thinking my waterpump is toast.
Rad is pissing a bit after I turn the car off.
I can here the Rad Fluid Bubbling
Engine shoots to red in under 5 minutes...
Rad is full.
No Rad Fluid in the oil...
1994 318is-Sold July 13th 2010.. Sad Sad Day
Nascar318is is offline   Reply With Quote
Old 08-26-2008, 04:16 PM   #2
Arash
Arash's Avatar
thermostat?
Arash is offline   Reply With Quote
Old 08-26-2008, 04:19 PM   #3
QUEEN AJAILA
SHATTA M3
QUEEN AJAILA's Avatar
Send a message via MSN to QUEEN AJAILA
IF U NEED a rad u can have if thats what u need
QUEEN AJAILA is offline   Reply With Quote
Old 08-26-2008, 05:03 PM   #4
carjoe
carjoe's Avatar
rad cap?
Might as well do it all since you've got the system open...
93 325is - sold!
2000 540ia- sold!
carjoe is offline   Reply With Quote
Old 08-26-2008, 05:55 PM   #5
jeffrie
Addict
jeffrie's Avatar
Ususaly you will have no flow without a WP ie rad wouldn't even get hot as no "hot" coolant is pumped to it, when cold take off the rad cap and start it, see if theirs any coolant pissing out of the little hole up top were the threads are for the rad cap, no flow = air in system, stuck closed t-stat or waterpump.
Hopefully you will not see a whole lot of tiny bubbles bubuling up in the coolant bottle and building pressure...That is the sighn of a blown head gasket.
"They say ignorance is bliss..... I don't know what the Fu*k that means but I'm pretty happy". Ricky Trailer Park Boys.
Current Mods....X-Brace, Stromung Cat Back Exhaust, 17/225/45 M3 Replicas, HotBits Adjustable Coil Overs, 40% LSD 3:91 Diff, E30 Gearbox, Boosted.
jeffrie is offline   Reply With Quote
Old 08-26-2008, 08:48 PM   #6
Nascar318is
Jeff: So far I turned the car on, opened the bleeder screw for the air, and alot of steam was coming out and hardley any spitting liquid(if that helps) also I noticed that the pipe going back into the rad(lower hose) was cold as crap and I was at 3/4 temp and then turned the car off. After the car was off that's when I noticed the hose start to get hot.. So any more diagnostics for me? I'm off all week and would be nice to fix this asap..
Old 08-26-2008, 08:56 PM   #7
Jamil20
It sounds like a thermostat to me.
Jamil20 is offline   Reply With Quote
Old 08-26-2008, 09:04 PM   #8
ecuconnection
ecuconnection's Avatar
while we are on the subject ... I replaced my rad and never put back the sensor that screws in the radiator housing and haven't noticed anything wrong ... It's obv a temp sensor but what does it tell the DME to do ? is it very important?
ecuconnection is offline   Reply With Quote
Old 08-26-2008, 09:21 PM   #9
Nascar318is
Oh man I hope you are right.. could do that tomorrow.. I hope it's as cheap as my tercel $15 lol
Old 08-26-2008, 09:25 PM   #10
jeffrie
Addict
jeffrie's Avatar
Well that bleeder screw has always been useless for me, should follow it to the open bottle and look their.
IMO from what you have described; since you had a almost overheating engine (3/4's to red) and only one hose is hot = to me a T-stat (stuck closed), air in the system (would need alot to stop that much flow) or most likly the WP.
FYI I'm off tommorow @ 11:30am... Want me to pick up the dealer only T-stat for you from Elite BMW? I can easily stop by since I drive by it on my way home and deliver it for you.
Edit: FYI I do not know were you live anymore or seen your new house yet.
Bear that sensor is to turn on the aux electric/AC fan if you were to ever get stuck in traffic and it's +40C outside which would need the extra air flow.
Old 08-26-2008, 10:13 PM   #11
carjoe
carjoe's Avatar
Jeffrie, I'll meet up with you to give the pump to Tony. I work at the Hospital on Smyth, Elite is around the corner...
93 325is - sold!
2000 540ia- sold!
Old 08-26-2008, 10:42 PM   #12
jeffrie
Addict
jeffrie's Avatar
Sure butt... wait and see what Tony is doing first in case he's up in Ottawa and might want to do everything himself.
Old 08-26-2008, 11:02 PM   #13
chromius
chromius's Avatar
I'm with Jeff, definitely sounds like the water pump. I've seen your exact symptoms on other cars with WP failures.
chromius is offline   Reply With Quote
Old 08-26-2008, 11:06 PM   #14
ecuconnection
this is what maybe has happend up in there
Old 08-27-2008, 12:00 AM   #15
Nascar318is
Oh crap yeah that's wicked.. Jeff Give me your cell I'll pop by CT in the AM to see if they have any. Wonder what the dealer Charges for those things...
Should have got those parts at NAPA in the US, $53 for the WP and $23 for the T-stat..
