Go Back   maXbimmer Forums > Platinum maXbimmer Sponsors > Bimmian
Old 10-20-2017, 03:50 PM   #1
Bimmian
Bimmian - New Product - Spray Film for Lights
Chameleon Spray Film is a highly flexible and transparent water-based coating suitable for automotive lens protection, revitalization and customization.
Features and Benefits Of This Product:
As the name implies, this product is applied using an aerosol method and once applied, it adheres to the surface of the lens, but maintains transparency. The chemistry of this product contains no solvents and will not damage lenses; its structure involves extremely large, interconnected molecules that form a tough, flexible adhesive film. It is the formation of these long molecular chains that facilitate the easy peeling and removal of the product when or if desired.
The kit comes with a bottle of water-based spray film liquid in your choice of color and a spray tool.
In order to apply the spray film, you will need to separately purchase a standard can of compressed air, usually sold in office supply stores as computer dust cleaner. The can of compressed air will serve as the propellant to spray the liquid onto the surface of your lens.
The bottle of spray film liquid and the compressed air are connected to the spray tool and work in tandem as a provisional airbrush. This method assures proper, uniform application.
The recommended application involves two spraying steps. The product will dry to create a form fitting membrane on the surface of the lens which serves to provide basic protection from road debris, can bring new life to older lenses, saving you the cost of replacement and offers several colors to allow you to customize the look of your lenses, while remaining highly transparent.
Note: When purchasing the can of compressed air, select a brand that offers the stem on the can. You can confirm this by pulling the atomizer off of the can. There should be a small stem protruding from the valve at the top of the can that the atomizer sits on. Some aerosol cans use an atomizer with an integrated stem that is inserted into the valve at the top of the can. This configuration is incorrect for the spray film applicator.
Available Colors:
  1. Yellow
  2. Blue
  3. Light Smoke - tints the lenses grey while muting the colors and chrome found behind the lenses.
  4. Dark Smoke - completely conceals all color underneath the film and gives the lens a completely black look. Note: This is extremely dark on headlights
What Its Made From:
Water-based liquid paint for aerosol application that dries to form a flexible membrane on automotive lenses. No oils or solvents are used in this formulation.
What's Inside The Box:
  • 1 bottle of spray film liquid
  • 1 spray tool
  • 1 feed tube
*NOTE: Due to the fact that shipping and carrier regulations restrict the transport of compressed gas products,you will have to purchase a can of compressed air from your local office supply store. This component is integral to the operation of this product, but is not included in the kit.
Installation Notes / Precautions:
  • For best results and to ensure safety, please follow all instructions to the letter
  • This product utilizes a compressed propellant. Always provide adequate ventilation during the application process.
  • This Product must be installed at room temperature. The vehicle must be allowed to acclimatize to the ambient temperature to ensure that the film adheres properly.
  • Prior to application, ensure the surface that the product is to be applied to is clean.
  • Mask off the area around your lenses to protect your vehicle from over spray.
  • Two coats of this product are required; allow at least 15 minutes of drying time between coats.
  • Please allow 12 hours for the product to fully cure before exposing it to harsh environments.
Compatibility: For all vehicles
Installation Difficulty: EASY (Most People Can Do This With Common Household Tools)
Bimmian is offline
Tags
bimmian, lens, lighting, spray film
