Old 04-15-2019, 08:40 AM   #1
Espritv8
Espritv8's Avatar
E39 M5 ABS module brake bleeding
Hi Guys
I'm suspecting I may have air in the ABS module. I'm getting the ABS DSC light after bleeding with my pressure bleeder, so i'm thinking air got in the ABS module. I'd like to clean and inspect/replace my pressure valve too and I will need to re-bleed the system after also.
I have INPA and BMW Scanner on my laptop, but can't find the procedure on how to do it. But there's a menu to open valves and activate the pump on INPA...
Apparently DIS has the option to do the full bleeding procedure, but I don't have the program and want to avoid messing with it.
Thanks for your help!
Espritv8 is offline   Reply With Quote
