Old 03-04-2006, 05:59 PM   #1
super_namer
How Do I Remove The Deck?
Hey guys,
Just a question about how to remove my deck on my e36...
i had a shop install it, but now i want to input an auxillary device in and need access to the rear of the alpine headunit...
any ideas?
super_namer is offline   Reply With Quote
Old 03-04-2006, 06:20 PM   #2
AJL
was there not a key with the deck? YOu slide it into the two holes behind the face plate and it removes... I could be wrong but it was like that on the last aftermarket deck i bought
AJL is offline   Reply With Quote
Old 03-05-2006, 08:55 PM   #3
bmw_tech84
Originally Posted by super_namer
Hey guys,
any ideas?
well if it's anything like my alpine deck then you have to remove the decorative ring that surrounds the deck first then at the bottom of the deck on both sides (right at the corners) you will see 2 little pins that stick out just a bit. lift thos up and slide the deck forwards.
bmw_tech84 is offline   Reply With Quote
Old 03-05-2006, 10:25 PM   #4
Justin e36
Justin e36's Avatar
1. what type of vehicle (year / model)
2. what deck do you have installed?
3. moved this thread to sound/audio.
Old 03-05-2006, 10:26 PM   #5
Primus
super blinger
Primus's Avatar
bmw has designed it so you cannot remove the deck...
Primus is offline   Reply With Quote
Old 03-05-2006, 10:28 PM   #6
super_namer
Sorry about the wrong category
94 325i
deck : Alpine CDA - 7864 (i believe its a 2000 or 2001 model)
Old 03-05-2006, 10:47 PM   #7
Justin e36
Justin e36's Avatar
Okay. Your deck should've came with a metal thingy... this metal thingy is a key to take your deck out. If you've thrown out your box, then you can get this from pretty much any stereo shop.. they usually have a box of these things at the back, and can take your deck out for you. If this isn't an option, or you're too lazy to bother (like me), then:
1. remove the plastic trim around the deck.
2a. you'll see flat metal tabs on either side of the deck. Use a flat head screw driver in the middle of this tab (on the outside of the tab, away from the deck), and pry towards the deck. The deck will push out. Do the same on the other side. Then pull the deck the rest of the way out by hand.
2b. if your deck does not have tabs on the side, but an actual lock further back, then you'll need a butter knife. Slide is down the slide and give it a hard shove.. it'll push the locking mechanism and the deck will unlock. Easier if you get two butterknives, and do both sides at the same time.
