Old 11-11-2005, 01:48 PM   #1
dave328i
dave328i's Avatar
Send a message via MSN to dave328i
radio says "PHONE".. can't enter code.. help!
recently my stock radio in my 97 328i stopped working.
it says "PHONE" on the display, and won't let me enter my unlock code. i tried calling a dealership and they said that i have to bring it in. is there any way to fix this problem myself? i looked in the manual and there is no info on this.
thanks in advance
dave328i is offline   Reply With Quote
Old 11-11-2005, 07:51 PM   #2
Hound
V-Dub in da House
Hound's Avatar
Send a message via MSN to Hound
personally i would take her into the dealership and see if they are going to charge you. if it's something easy and not replacing any parts or w/e then i doubt that they would charge you but you never know.
Sean
07 GTI, Revo Stage II, 3" catless GHL exhaust, OEM R32 rear conversion, 17x9 + 17x11 215/45/17 all around on genuine BBS RS's, B&G RSII coilovers
96 Harliquin Golf
Hound is offline   Reply With Quote
Old 11-11-2005, 07:55 PM   #3
paul christians
87325is///MR.EVIL
unhook the battrey or is there a reset botton????
87is325///2.7L..EVIL.....
03 beige GRAND AM and 94 white (slamed) PROTEGE
paul christians is offline   Reply With Quote
Old 11-12-2005, 09:10 PM   #4
dave328i
dave328i's Avatar
there is no reset button, and i'm scared to disconnect the battery because won't that mess up the computer in the car?
Old 11-12-2005, 10:44 PM   #5
Justin e36
Justin e36's Avatar
which stereo option do you have?
do you have a car phone / cell phone?
does your vehicle come with a cell phone auxillary port? is something plugged into it?
disconnecting the battery and reconnecting it won't mess up the computer in the car. repeated voltage spikes & dips may... like when giving someone a jump-start.
J
Old 11-13-2005, 11:12 PM   #6
dave328i
dave328i's Avatar
J
the stereo that i have is called the business radio, it's an am/fm with a tape deck and a 6 cd changer mounted in the trunk.
i don't have a car phone and there is no aux port that i can find/use.
i did some more research and it looks like this is a common problem, however nobody seems to know of a good fix. apparently the radio may be stuck in car phone mode (because when an incoming call comes in, it mutes the radio and goes into phone mode) however there is no evidence of a phone ever being used in the car. maybe some kind of outside frequency has triggered it.
i know that if you let your car run (or leave the key in position 2) for 1 hour and 15 minutes it lets you try to enter your code again, but the radio is not prompting me for the code, nor have i entered an incorrect code.
i don't want to resort to unhooking my battery...
does anyone know of a way to reset the radio (a combination of buttons that can be pushed or something)...
thanks again
Old 11-14-2005, 03:08 PM   #7
Justin e36
Justin e36's Avatar
thanks again
that's what i figured the problem is... but there's a port on the radio that your phone needs to be wired to so it goes to phone mode... it doesn't happen from just signal alone. for some reason the radio believes there is a phone call in progress.
if you don't want to disconnect your battery, then you can remove the deck and unplug the power from it, the fuse from the back, or check the fusebox under the hood for the radio fuse, and pull it from there.
J
Old 03-11-2006, 08:25 PM   #8
dave328i
dave328i's Avatar
bumping up this old thread to see if anyone has any ideas.
i managed to pull the deck out, take the fuse out, unhook the wiring harness, and put it all back, and i still get the same "PHONE" message on the display.
i guess my only option left is to disconnect the battery...
man, it really sucks having no radio.
anyone know where to buy an adaptor that will allow me to install an aftermarket deck?
will i have to remove the stock amps in the car?
Old 03-11-2006, 08:39 PM   #9
Justin e36
Justin e36's Avatar
... you can buy the adapter from any car audio store, even Future Shop. If they don't have it, they can order it in for you... or just splice into your current wires.. not tough. You don't have to remove your stock amps.
