Old 03-01-2006, 04:35 PM   #46
makker
indeed i am. the 3.0 is powering a set of 5 1/4 MB Quarts up front and a set of 4" MB's on the rear deck.
6.0 is powering a JL 10 in a ported box. Not hard to tell where the weakest link is there But for sizing issues, the JL is in a tiny box, so i have plenty of trunk space to spare
makker is offline   Reply With Quote
Old 03-01-2006, 07:34 PM   #47
paul christians
87325is///MR.EVIL
your power out put is the same,becusae the 3.0 running 2 ohm st and 6.0 is runnig 4 ohm mono, you can run 6.0 to 1 ohm mono and that is 3 4 ohms woofers, if you did not know...
87is325///2.7L..EVIL.....
03 beige GRAND AM and 94 white (slamed) PROTEGE
paul christians is offline   Reply With Quote
Old 03-02-2006, 09:31 AM   #48
makker
I was thinking more of pulling the 10" and replacing it with 2 -12"s. I've had occassion where i've needed to pull my subs to reclaim trunk space, so having a small box that I can swap out would allow me the luxury of still having bass when I need the extra cargo room.
At least, that's how my convoluted mind works
Old 03-02-2006, 11:45 AM   #49
paul christians
87325is///MR.EVIL
The ID come duel 4ohm so makes it a 2ohm load, but you run 3 4ohm woofer on the 6.0...
Old 03-02-2006, 12:13 PM   #50
makker
it's been awhile, so i'm a bit groggy on this, but if i run 3 subs with DVC in full parallel, how much of a load would that present to the amp?
Old 03-02-2006, 05:29 PM   #51
paul christians
87325is///MR.EVIL
^^^3 dvc subs would be bad,6 4ohms is a dead shrot .00001 ohms,what I ment is single 4 ohms which = 1ohms, but very safe about it, run 3 8ohms and that is 2 ohms,and the 6.0 can handle that...
Old 03-02-2006, 05:36 PM   #52
makker
I was actually thinking about picking up 2 Boston Acoustic G512s, and running them DVC in parallel which if not mistaken, should provide a 1 ohm load. Now my math might not be what it used to be, but I know i've had the 6.0 running at about a 1/2 ohm before, and she never let me down. The joys of a 1/4 ohm stable amp!
Old 03-02-2006, 05:49 PM   #53
paul christians
87325is///MR.EVIL
^^^^heheheheheh...sweet....
Old 03-02-2006, 07:04 PM   #54
makker
I'm hoping. Although I'm not the bass head I once was, and I definitely prefer SQ over SPL, it's nice to be able to feel the thump every once and awhile
Old 03-02-2006, 11:05 PM   #55
paul christians
87325is///MR.EVIL
oh yes I hear that dude...cheers..
