Old 03-11-2003, 12:26 PM   #1
Cosmic 325i
Cosmic 325i's Avatar
shifting problem
i dont know what it is but going into second gear is not smooth like it used to be. all the other gears go in nice and smooth but second feels kind of notchy...any ideas of what it could be?
Cosmic 325i is offline   Reply With Quote
Old 03-11-2003, 12:47 PM   #2
Fernando
Fernando's Avatar
Re: shifting problem
when you downshift from 3rd to 2nd does it grind, if so, it could be the syncronizer...
Could also be something as simple as clutch fluid low.
If you have hydraulic clutch...
Check clutch fluid level, make sure it is always at proper level. Much like the brake fluid, in that if it gets too low, then air gets into the system and has to be bled!.
If fluid is low could be clutch smaster cylinder that is leaking.
Just my $.02
Cheers,
Fern
"I told you a million times, I hate it when you exaggerate !"
Fernando is offline   Reply With Quote
Old 03-11-2003, 04:42 PM   #3
MP328
Krv Svoju Za Bosnu Moju
MP328's Avatar
Send a message via MSN to MP328
do u mean when the car is cold and u take off and u can barely get it into second gear?
if that then don't worry is just to damn cold, my car does the same thing. i really gotta jamm it in on a cold night. but once it warms up is just like usual right?
MP328 is offline   Reply With Quote
Old 03-12-2003, 05:26 PM   #4
Cosmic 325i
it doesnt grind when i put it into the gears though! i didnt check my clutch fluid yet, but if it was low wouldnt it be doing the same thing in every gear and not just second? the weird thing is after i posted this thread i threw it in to second quickly and now it seems to shift betterthan it did before? What the hell?
Old 03-25-2003, 07:21 PM   #5
MikesJo
Hey i have that grinding issue! 3 times in the last 3 weeks when i put it into first at a light it would grind for a second and i'm like (wtf). Whats the problem or what needs to be changed? Also how do i get the smooth shifting feeling back, my buds e30 is so much smoother than mine for some reason
Thanks!
MikesJo is offline   Reply With Quote
Old 03-25-2003, 10:33 PM   #6
where is ur clutch fluid container?
bmwm5lover is online now   Reply With Quote
Old 03-26-2003, 12:14 AM   #7
Autotechnica
Little Chino
Thanks!
Your syncrose is going. Probably either you or whoever owned your car previously misshifted a lot. It grinds the gear's teeth while wearing it out and each time you shift it misshifts and that's why it grinds. This is only going to get worse with time. And if it only happens at really high RPM's then the problem is just beginning, if it happens very often at low RPMs that means your messed. Eventually it will get so bad that you can't even push it into gear and you will have to rebuild your gear box. $$$$!!!
Bry
Old 03-26-2003, 01:20 AM   #8
MikesJo
This happened only when i'm shifting from a complete stop into 1st so shifting at idle not high RPM's. What do i need to change?
Old 03-26-2003, 01:51 AM   #9
Autotechnica
Little Chino
Your first gear is busted. You will need a replacement soon and you will have to remove your gear box. The gears are dirt cheap, but the labour to remove the gear box is pricey. I'm positive it's the worn out teeth on the gears.
Bry
Old 03-26-2003, 03:04 AM   #10
MikesJo
Ok thanks. Someone told me it's a worn out syncro.
Old 03-26-2003, 04:38 AM   #11
Darren
Here's my problem:
Ever since installed I had motronix short shifter installed, I get a grinding + difficulty when shifting from 5th to 4th and from 3rd to 2nd only. However, this problem does not happen on the way up at all (from 1-2-3-4-5). I have no clue what it is but it is extremely annoying and I do not want to cause any type of damage. Anyone got ideas ???
Darren is offline   Reply With Quote
Old 03-28-2003, 02:07 AM   #12
tiestoE36
tiestoE36's Avatar
i also have a shifting problem, sometimes it wont go into 1st gear, i have to quickly shift to 2nd then to 1st in order to get going fom a full stop.
tiestoE36 is offline   Reply With Quote
Old 03-28-2003, 02:11 AM   #13
tiestoE36
tiestoE36's Avatar
i was just reading some of teh other post, ones that have similar problems getting into first. mine dont grind, i just have a hard time putting it in. it happens every once in a while.
plus sometimes as i am shifting out of first, i will have the clutch in all the way, but it fells as if i am pulling out of gear i with out a using the clutch.
can any one help??
Old 03-29-2003, 01:21 PM   #14
thinair
moderationistismingly
thinair's Avatar
I have the same problem, I'm going to bleed my clutch soon. If I have the car one a slight incline with the car off and in gear, and press the clutch the car won't roll down the incline, but if I take the car out of gear the car starts rolling right away. I think the clutch isn't disengaging properly (air in the clutch line).
Old 03-29-2003, 05:03 PM   #15
Autotechnica
Little Chino
Same here, and I thought it was broken or something. Seems like everyone has the same problem.
If you find out what's the cause of this problem, please let me know. It's really annoying.
Bry
