Old 04-13-2008, 07:33 PM   #1
rwdbmwm3
Aftermarket Deck Installed - No Sound??
Is there anything extra you have to do when installing an aftermarket deck other than just connect the proper wires?
Deck= ALPINE ( i will have to check the model # )
OEM deck works fine
Alpine works but no sound, do you need an aftermarket amp or somethin like that?
rwdbmwm3 is offline   Reply With Quote
Old 04-13-2008, 08:04 PM   #2
Robb
EX E30 M3 Owner
Robb's Avatar
check deck fuse..
Old 04-13-2008, 08:35 PM   #3
rwdbmwm3
like i said, deck works fine, just no sound
Old 04-13-2008, 09:17 PM   #4
wraith318
wraith318's Avatar
i just did mine .... if you want to discuss things give me a PM.
wraith318 is offline   Reply With Quote
Old 04-14-2008, 10:24 AM   #5
Nascar318is
Nascar318is's Avatar
What about your remote wire(think it's the blue one) Hook that up if it's not. I did that as well everything hooked up and no sound, hooked up the blue? (remote) wire and got sound.
Old 04-14-2008, 07:03 PM   #6
KIRASIR
Your Nightmare
KIRASIR's Avatar
Sounds like your built-in amp is not getting 12v (It think it's white wire, make sure it's connected).
SL
Old 04-14-2008, 07:09 PM   #7
///tyron
///tyron's Avatar
SL
+ 1
///tyron is offline   Reply With Quote
Old 04-15-2008, 08:47 PM   #8
rwdbmwm3
connect the remote wire to where?
i am pretty sure i connected the white wire to 12V but i will double check
Old 04-15-2008, 10:52 PM   #9
elroy
did you use a universal harness or go hardwire the deck?
did you use all wires? (because you shouldn't have too unless you've got an antenna that retracts and extends when cars shutoff/on, external amp) tell us what wire(s) you haven't used
elroy is offline   Reply With Quote
