Old 04-16-2010, 01:36 AM   #1
aaron320i
Banned
Send a message via MSN to aaron320i
Lightbulb How to reprogram your key.
In order to reprogram your key you must:
1. Put the key into the ignition.
2. Turn to the on position for approximately 2-5 seconds then back into the off position and remove the key.
3. Press and hold the "unlock" button, while holding down the "unlock" button, press the "lock" button 3 times, you should hear all the locks cycle through.
4. Then turn the ignition on and off again to exit programming mode.
Cheers.
aaron320i is offline   Reply With Quote
Tags
battery, fob, key, lock, reprogram
