Old 07-15-2012, 11:43 PM   #16
starbuck
as others have already said: Front control arms, control arm bushings, tires are all common things that cause vibration on the e46.
A few other things that I have come across on my own car that might create vibration: bent rim, warped brake rotors.
Obviously because you experience this issue with 2 different sets of rims and tires, those probably are likely not the problem.
starbuck is offline   Reply With Quote
Old 07-16-2012, 10:54 AM   #17
EMPOWERD
EMPOWERD's Avatar
Another important point that hasn't been brought up yet is whether the hub bore diameter on your wheels are the perfect size (72.6mm) to fit over the OEM hubs (72.5mm). If they're slightly larger, your wheels are now mounted bolt-centric (instead of a proper, accurate hub-centric). This is why some aftermarket wheels require those plastic hub rings.
My YouTube video
-- RANDY SPARRE --
Old 07-18-2012, 04:00 PM   #18
e46it
e46it's Avatar
dont think its the hub, cause as i said before i was having the same issue with oem rims in winter.
the car is going to BMP on Tuesday for coil-over install and heavy duty bushings... we see what they find out!
2004 BMW 325i Touring SGM
2005 Suzuki GSXR 1000|1992 JDM Civic SiR RHD Black
2000 BMW M5 Avus Blue (GONE)
2002 BMW 325i Touring TVM (GONE)
1994 BMW 325i Saloon Black (GONE)
e46it is offline   Reply With Quote
Old 07-25-2012, 11:47 AM   #19
e46it
e46it's Avatar
My shaking problem has been resolved, it was realted to one of the front shocks being blown. after having coil overs installed the car does not shake anylonger between 100 to 120.
Old 08-31-2012, 09:10 PM   #20
tin-man
I agree. Control arm bushings are likely the issue here.
tin-man is offline   Reply With Quote
