Old 06-06-2012, 08:45 PM   #1
Nipuna
Nipuna's Avatar
KW V2 coilover height adjustment help
Hello, could anyone let me know how to adjust the height (raise the rear) on 2004 M3 with kw v2 coils?
I'm just looking to raise the rear a little maybe 0.25inches.
Thanks for your help in advance
Nipuna P
Nipuna is offline   Reply With Quote
Old 06-06-2012, 09:23 PM   #2
5ABIVT
Cheap reliable fast.Pick2
did you install them yourself?
5ABIVT is offline   Reply With Quote
Old 06-06-2012, 09:35 PM   #3
Nipuna
Nipuna's Avatar
No i had RMP motors install it for me
Nipuna P
Old 06-06-2012, 09:39 PM   #4
Steve30
Techno Viking
Steve30's Avatar
there's an adjuster between the body and the rear spring. Just spin it with the wrench KW gives you until you reach the desired height. Looks like this
E36 ///M3 S54
STock 335i "The Punisher"
Old 06-06-2012, 09:39 PM   #5
Maple
Go back to them and ask them to do it or you'll mess it up.
I mean if you have to ask such simple questions ..... better have someone else do it for you
Maple is offline   Reply With Quote
Old 06-06-2012, 10:25 PM   #6
5ABIVT
Read the instructions and search some forums on installs. theres a lot of DIYs. Nothing against RMP I wish you had tried the install yourself. Its a great way to learn about the suspension and adjustments would have been so easy.
If you really need help and noone will do it without charging you I'd be happy to do it for you at my place sometime. By the looks of it the rear is a coilover and not 2 seperate pieces and the adjuster is at the top. I didnt dig too much but looks like the easiest way is to just put up the rear of the car and drop both arms together and pull and adjust.
Old 06-07-2012, 08:16 AM   #7
Nipuna
Nipuna's Avatar
Thank you.
So you don't think I would have to remove the spring to adjust?
Nipuna P
Old 06-07-2012, 08:17 AM   #8
Nipuna
Nipuna's Avatar
Very true point, but I rather learn myself and do it so I wouldnt have to pay every time and drive so far you know
Nipuna P
Old 06-07-2012, 08:19 AM   #9
Nipuna
Nipuna's Avatar
the rear is two different pieces, the shock is separate from the spring
thanks for the offer I will definitely keep that in mind
Nipuna P
Old 06-07-2012, 11:32 AM   #10
Steve30
Techno Viking
Steve30's Avatar
I usually just grab the spring with my hand and compress it a little bit. It makes turning the adjuster a lot easier.
E36 ///M3 S54
Old 06-08-2012, 09:51 AM   #11
Nipuna
Nipuna's Avatar
Thanks I will try it out tomorrow.
Appreciate it Steve
Nipuna P
