Old 12-01-2014, 05:41 PM   #1
Youngkashi3
S50 325iX e30
I just bought 2 e30s both all wheel drives. 1 has a blown motor and i was thinking about dropping an S50 from an e36 into it.. Is it possible? If yes then what would i need to buy and how much would it cost? Or if there are any other threds that have done it more and could explain it in detail
Thanks in advance.
Youngkashi3 is offline   Reply With Quote
Old 12-01-2014, 08:25 PM   #2
Steve30
Techno Viking
Steve30's Avatar
http://www.e30zone.net/e30zonewiki/i...ine_Swap_-_M5x
E36 ///M3 S54
STock 335i "The Punisher"
Old 12-01-2014, 09:08 PM   #3
Youngkashi3
But is it the exact same thing when it comes to my E30 being awd?
Old 12-01-2014, 09:35 PM   #4
Steve30
Techno Viking
Steve30's Avatar
not exactly. the awd requires some extra work. Its quite a bit more expensive than doing a rwd e30. check out this thread. looks like you have to have a custom made oil pan. http://www.e30tech.com/forum/showthread.php?t=21774
E36 ///M3 S54
Old 12-02-2014, 01:13 AM   #5
Absolutely anything IS possible. Only question is how, and how much!!!
I don't think anyone can give you a clear amount, and even if they do, not sure if you can get it done for the same. When it comes to hard to find parts and custom fabrication, no two jobs are the same. Might have more luck with a Turbo build on the AWD...
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 12-02-2014, 09:55 AM   #6
cheapthrills
The only M5x motor with AWD was the E34 525ix, which was only sold in Europe. You can swap lot of those parts to make it work, and you'd basically wind up with the E34 AWD system, which is, in many ways, not as good as the E30 ix.
You can also use your existing transmission, TC, etc and make a frankenstein oil pan. Welding cast aluminum is difficult.
Either way, this is difficult and expensive.
http://www.r3vlimited.com/board/showthread.php?t=271604
cheapthrills is offline   Reply With Quote
Old 12-23-2014, 03:03 AM   #7
boogle2
I saw those for sale, the pair in the SW, right?
If you would be willing to sell one of the ix drivetrains, I would definitely take one of them off your hands.
boogle2 is offline   Reply With Quote
Old 12-24-2014, 01:32 PM   #8
estoguy
For the sake of the hassle, I'd just rebuild the M20.
1986 325 ~Elsa~
Alpenweiss
Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectives
"The future is uncertain and the end is always near."
estoguy is offline   Reply With Quote
Old 12-25-2014, 01:46 AM   #9
Red_Liner740
all you have to ask yourself is....why?
A turbo iX will make tons more power than an m50/s50 swap.
- 1994 530iT: M60B40'd + 5spd conversion, 18" Style 32's, Magnaflow catback, Voltglands, angel eyes, Erebuni ACS body kit, 10" sub and amp, Alpine deck, soon to be supercharged!!
- 1984 635CSI: 92 535 M30 5spd, Koni Yellows, Eibachs, Magnaflow cat + catback, short throw shifter, Style 5's, 2x 10" subs, soon to have 3.46LSD. STOLEN! baby's gone.
Red_Liner740 is offline   Reply With Quote
Old 12-27-2014, 10:15 AM   #10
you dont have to use the e34 awd system. afaik you have to cut the m50 ix oilpan and weld it together with the s50 one. midnight autoworks (sp?) in the states have a grey one.
the guy who bought my iX wanted to do this but ended up rebuilding the m20 and boosting it due to practicality.
Old 12-27-2014, 10:47 AM   #11
24vofTouring
betterwiththebackendout
the e30 ix transfer case will not hold the torq of the S50.
There is a guy on bcbimmers.com named Matt who tried this project out. I dont think he succeeded in getting it to work.
1988 e30 325i Touring 5speed 3.73LSD conversion - MalachutGrun Metallic
1991 e30 318is 4.10LSD - DS Black
1995 e34 540i/6 Touring conversion - Schwartz Black
1992 e34 525i Touring 5speed 3.46LSD conversion - Island Grun Metallic
24vofTouring is offline   Reply With Quote
Old 12-27-2014, 10:48 AM   #12
24vofTouring
you can get 250hp 260tq out of a bolt on turbo'd M20 and from there you may get away with not blowing the xfer case.
Old 12-31-2014, 10:36 AM   #13
supernaught
supernaught's Avatar
xfer case won't blow due to that. It can handle a lot more power/torque. The front diff will explode first.
The xfer case will give up if not maintained properly or if it's already seen some damage.
There are a lot of turbo ix's out there above 300-400 that are not blowing xfer cases(chains or VCs) - look to europe.
But on that note, make sure your TC(VC) is in good condition before you throw more power at it then blame your TC for being the weak link.
http://www.e30tech.com/forum/showthread.php?t=45891&page=5
Old 01-01-2015, 12:32 PM   #14
24vofTouring
problem is with most IX's that if they have been towed once in their life dragging the back wheels, the xfer case is pooched.
Tags
325ix, awd, e30, s50, swap
