Old 01-13-2007, 10:22 PM   #46
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
Originally Posted by JazzM
turbo...
T.
What he said I'll officially put it up for sale this week. Tom still thinking?
Sickbimmer is offline   Reply With Quote
Old 01-14-2007, 12:00 AM   #47
Manimillion
Photographer
Originally Posted by X5HogTown
re Check the trunk...
Check the rear for diff mount and subframe tears and broken welds.
http://www.thelargeglass.com/bmw/subframe/
A fair number of cases. Affects all Z3s. Adding additional power will provoke the problem. I'm sure Tom will give us the technical details.
Manimillion, the car I PMed you about was fixed by BMW.
How hard is it to prevent this from happening if a car doesn't have this problem yet?
And is there any permanent solution?
Manimillion is offline   Reply With Quote
Old 01-14-2007, 01:59 AM   #48
X5HogTown
Goin' Diesel
X5HogTown's Avatar
I installed Ireland Engineering urethane subframe mounts on mine. This reduces the play and transfers more load onto the main mounts. This 'might' help prevent the problem but it's not a permanent solution. If you're going to subject the rear-end to excessive shock, you'll need to get a kit from Randy Forbes or Dinan. This will cost a few bucks but it will be built like a brick shithouse when you're done.
I would get the urethane subframe mounts to start. Install a kit if and when it's required.
X5HogTown is offline   Reply With Quote
Old 01-14-2007, 02:36 AM   #49
JazzM
Stay away from the dinan kit... there's a lot of articles around comaring the RF kit to Dinan.
Also its a lot less exensive to install the RF kit prior to any significant damage occuring. It will look like stock as well, like it came from the factory.
Good point on the IE urithane bushings. I had those for about a year before the subframe issues started to take place (my car will be 10 years old this coming may). You'll notice the welds in your trunk floor start to pop at first. That will be caused by the trunk floor seperating from the differential mount (subfloor). After that its a matter of months before you're in a lot of trouble.
Another way to stiffent the rear end is to use the butt-brace front strong strutt as well as the side brace. I have their front shock tower brace and have heard good things regarding the rear brace. I will most likely be getting it later on this year.
T.
T.
