Old 04-12-2011, 07:50 AM   #16
richie_s999
If clutch is pressed in and your getting the clunk, then it shouldn't be anything behind your transmission.
Edit... Even though your clutch has lots of meat, there are other parts it could be, shifter linkage or transmission itself could be clunking
Old 04-12-2011, 09:24 AM   #17
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Of all clutch components, I'd suspect the release bearing first. Those things are built like shit. Plastic, and often not lubricated correctly at small shops.
Old 04-12-2011, 12:01 PM   #18
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I'm with BigD, sounds clutch related. I had a similar issue on my e30 years ago, turned out to be the slave cylinder was on it's way out and was seeping a bit, which didn't release the clutch fully.
Old 04-21-2011, 09:48 PM   #19
jethie
jethie's Avatar
thump when engaging in 1st and reverse, had the same problem last week, diff bolts are loose...thighten bolts and its good to go....
jethie is offline   Reply With Quote
Old 04-22-2011, 05:42 AM   #20
98Dinan3
98Dinan3's Avatar
another vote for diff bolt
Old 04-22-2011, 08:59 AM   #21
InfiniteDice
Mine does it slightly with everything tight.
Driveline lash... Most likely the bearings on the output shaft of the tranny or input shaft of the diff causing play in the mesh.
Alot of these items go owner to owner and have never been rebuilt. Everything wears out eventually (futuristic nanotech parts exempted).
Old 04-28-2011, 10:42 PM   #22
Singe
BGDorcol
Singe's Avatar
Didn't get a chance to look it over yet, hopefully this weekend i can get it on a hoist at a friends shop and look everything over...thanks for the responses guys
Singe is offline   Reply With Quote
Old 04-28-2011, 10:48 PM   #23
WlodeK84
Originally Posted by SiR View Post
sounds like typical driveline lash to me...
+1
I have issues with my driveline lately and changed the Centre Support Bearing and Guibo (Flex Disc). I also get the thump some times when engaging firts gear. I agree it's just driveline lash.
WlodeK84 is offline   Reply With Quote
Old 04-28-2011, 10:50 PM   #24
fitter527
hates chrome
fitter527's Avatar
mine's been doing it since the day i bought the car.i read on some other forums it's "normal"
fitter527 is offline   Reply With Quote
Old 04-28-2011, 11:45 PM   #25
SiR
Vtec just kicked in
well it is for the most part. provided its not some obnoxious bang.
a car is a mechanical system. it makes noises , even(err especially) bmws.
-||Old Crayons||-
