Old 12-01-2009, 12:46 AM   #1
Sergsam
Master
Sergsam's Avatar
Wiring diagram for BMW
I am looking a wiring diagram for 525 E39.
Any advise, where can I find it.
PLEASE.
Sergsam is offline   Reply With Quote
Old 12-01-2009, 01:13 AM   #2
nachos23
SweetXi
nachos23's Avatar
everything you wanted to know..... Just select your model and happy hunting.... http://www.bmw-planet.com/diagrams/release/en/index.htm
You will be prompted to install Adobe's SVG viewer...... Install and you're good to go....
Old 12-01-2009, 10:16 AM   #3
Sergsam
Master
Sergsam's Avatar
Thanks!
THANKS!
It has to be very useful.
But, I can't see a navigation tree.
I have Adobe SVG viewer, I work with CAD design.
How I can open a navigation tree?
Old 12-01-2009, 10:49 AM   #4
ScotcH
check your browser security settings ... works fine for me. Or try a different browser (I tried it in IE 7 and 8)
Old 12-01-2009, 12:32 PM   #5
nachos23
SweetXi
nachos23's Avatar
Got to be browser settings... Do U get the initial vehicle nav screen (where u can select model?)..... If so, then the next screen is split into 2 sections. On my screen, the left side is the main navigation screen (a pale blue background) and on the right it displays the contents. If you can't see right side SVG viewer not installed (maybe different viewer required; although shouldn't be)..... Could be security settings. Make sure you have disabled pop-up blockers for the site (Google and/or IE).... There is a thick bar separating the two screens. It can be dragged as required..... Let me know how it goes...
Old 12-02-2009, 12:05 AM   #6
Sergsam
Master
Sergsam's Avatar
" On my screen, the left side is the main navigation screen (a pale blue background)
- I can't see left side
- I can see right side
- I off all my security soft and internet option. But stiil get message that comp block some active file from this page. I tried everything......
- Thanks for your help.
Old 12-02-2009, 01:32 AM   #7
Dado 540
Dado 540's Avatar
I can see all the text, as for the diagrams no luck. Didnt ask for any adobe update
E39 540i Sport
Old 12-02-2009, 09:51 AM   #8
Sergsam
Master
Sergsam's Avatar
I tried computer on my workplace.
Now I can see navigation tree GREAT!
But nothing on the right side. No wire diagram.
Old 12-02-2009, 12:58 PM   #9
ScotcH
Lol.
Install the SVG plugin from adobe.
Old 12-05-2009, 11:27 AM   #10
Sergsam
Master
Sergsam's Avatar
Need help
Originally Posted by ScotcH View Post
Lol.
I have all this programs on my comp !!!!!
Even on my work place I can't open (read above post).
Please HELP. Drive without headlight terrible, especialy now!
Old 12-05-2009, 01:51 PM   #11
nachos23
SweetXi
nachos23's Avatar
PM Me...... We can talk live and figure this out.... leave cell # on PM.....
Old 12-23-2009, 09:00 AM   #12
Sergsam
Master
Sergsam's Avatar
The problem growing
My Great THANKS and Best Regards Mr. NACHOS 23 for help
But now I have more problems.
Now, sometimes my left or right LOW BEAM light does not work. Or work Good!
Bulbs are good, they did not get a power from Lamp Control Module.
I don’t know what to do: replace it – is not cheap part.
Must be sure that it is broken!
Reprogramming also not cheap work, especially in dealer shop.
Anybody has similar problem?
Please share your opinion.
Thanks.
Old 12-23-2009, 02:33 PM   #13
nachos23
SweetXi
nachos23's Avatar
Usually the switch. Hey buddy glad you got the software going..... The wiring from the low beam lamps goes directly to the switch. Suggest you give Filip @ Eurostyle @ 41-821-2578. Sure he will have one for much less than dealer. Other than that, check all connections for corrosion and abrasion (rub/short/open) circuits.... Also confirm good grounds.... Grounds are ofthen the issue..... Good luck buddy!
Old 12-23-2009, 02:41 PM   #14
Sergsam
Master
Sergsam's Avatar
What switch, on dashboard?
