Old 08-02-2003, 01:06 AM   #16
Autotechnica
Little Chino
Originally posted by nzer
I can add no gas at all and let the clutch in normal speed and it won't stall, provided its not uphill or anything. My idle is around 1300.
On a stock flywheel? Isn't that a little high? You may have you adjust your idle with your TB.
Bry
Old 08-02-2003, 06:49 AM   #17
Slowered318
Well for a fact i know drag racing cars use heavy flywheels so they hold the momentum of the engine when the car is launched.
A lighter flywheel will provide faster shifts, shorter breaking and quicker spool up but it really won't make your car any faster. think about when your on the highway cruiseing and you need the momentum of your flywheel to keep you at a constant speed.
Old 08-07-2003, 01:43 PM   #18
97 Z3 2.8
Mohammed,
Unless you plan on tracking your car don't bother with the lightened flywheel. If you weren't sure what it was and did you may want to do a few other things first. Try intakes, exhausts, software before you start getting to the guts of you're car. Swapping flywheels isn't the easiest thing unless you're pretty farmilliar with mechanics. If it does happen, you may as well throw in a stronger clutch while it's apart. Check out AA or Turner for pricing.
Bill
Bill
1997 Z3 with N/A power adders....
97 Z3 2.8 is offline   Reply With Quote
