Old 05-17-2005, 02:22 PM   #1
Micaela
Beemer Fanatic!
1987 325e Acceleration Problem, Help!
Hello,
I am having a problem with my 87 325e. In every gear at between 2.0 and 2.5 rpm the car is stuttering at hard acceleration. Why? I changed out the spark plugs, no change, it actually felt like it was getting worse. It's not the fuel pump, and I am going to change the fuel pump relay today, and check the distributer and rotor, what else should I check?
Micaela
Micaela is offline   Reply With Quote
Old 05-17-2005, 03:19 PM   #2
JCKL_racing
JCKL_racing's Avatar
check vacuum lines, afm, throttle butterfly and linkage?
Max money for Maxbimmers from your Max Financial Services guy. PM for details.
mortgages, leasing, debt consolidation and more
JCKL_racing is offline   Reply With Quote
Old 05-17-2005, 08:40 PM   #3
paul christians
87325is///MR.EVIL
do a leck down test aswell to be safe.........
87is325///2.7L..EVIL.....
Old 05-19-2005, 09:33 AM   #4
Griff
check the O2 sensor for output, as well as the AFM. My AFM had a dead spot on the potentiometer causing a similar problem. A new (used) AFM cured it. GL
Originally Posted by Micaela
Hello,
Phil Griffin
Toronto, Ontario
'86 325es
'85 VW GTI VR6
Griff is offline   Reply With Quote
