Old 08-07-2006, 12:26 PM   #1
Darkness95m3
Darkness95m3's Avatar
95M3 idling problem, need advice.
Have a problem with my M3.
The starter quit on me and I replaced it.
The car started fine with the new starter however it was idling @ 1250Rpm.
The car idled for about 5 minutes at this rpm and then all of a sudden revved to 3500 rpm
Until I shut it off. Error code read 1216 which meant throttle position sensor. I swapped it with my 540i since they were both the same part number.
The 540i started with no problems with the M3 throttle position sensor. The M3 with the 540i throttle position sensor had the same problem.
I removed the throttle body and intake again and checked for vacuum leaks did not findany. Re assembled the throttle this time code 1281 “Control Unit Memory Supply”. Tested the battery which seemed to be weak and bought a new one.
This time no code 1281 however the car idles @ 1250rpm and after a few minutes jumps up to 3500rpm.
Has anyone else experienced the same problem?
Darkness95m3 is offline   Reply With Quote
Old 08-07-2006, 12:43 PM   #2
BigD
the misanthropist
BigD's Avatar
Check the crank position and reference sensors, perhaps there's more than one. Some cars have it on the front hub, others take the reading off the flywheel. On the M30/20, for instance, the connectors for the CPS and reference sensor are on the starter bracket. Check for loose connections there or a hanging unplugged one. They probably didn't put one of them back after replacing the starter (doubt it's the CPS as usually that results in no starting, could be loose but that would result in horrible misfire, probably the reference [ie speed] sensor).
Old 08-07-2006, 01:03 PM   #3
Acidblast
Acidblast's Avatar
hmmmm that is very strange. maybe its the idle control sensor.
"Ooh, they have the internet on computers now" Homer J. Simpson
Acidblast is offline   Reply With Quote
Old 08-07-2006, 01:08 PM   #4
My car did something pretty similar, it was the throttle sticking. I doubt that's the explanation in your case but its worth a shot. Are both your temp sensors working? Part of your problem could be that the car is reading a cold start and thereby raising the idle RPM
Old 08-07-2006, 02:32 PM   #5
Darkness95m3
I thought of that also, however it does not explain why the revs jump to 3500 after idling for 3 or 4 minutes.It does this all the time.
I have disconnected each sensor one at a time.
The moment I unplug one sensor the car starts to sputter or the rpm’s jump way up.
Conclusion that it is not a sensor but a vacuum leak somewhere, the question is where?
Old 08-07-2006, 07:07 PM   #6
Are you running standalone or software for your FI setup?
Old 08-07-2006, 08:17 PM   #7
static
static's Avatar
easiest step is to try a different ECU
also TB might stick, but i don't think it's the case here. I also once had tape obstructing the HFM air passage (like 50% of it) and this resulted in car violently revving up and down.
hope this helps
static is offline   Reply With Quote
Old 08-07-2006, 09:33 PM   #8
thinair
moderationistismingly
thinair's Avatar
Don't forget to check the idle control valve, it might have gotten smacked around when pulling the starter out.
Old 08-08-2006, 02:25 AM   #9
BigD
the misanthropist
BigD's Avatar
Can the ICV really make your car run at 3500 rpm, can it let enough air go by? It's just a small bypass. The 1250 is more typical of an ICV stuck/left open.
Actually, Darkness, does it rev to 3500 and stay there, or does it rev up and down? The fact that it changes with time tells me it's the temperature system. While the engine is in warmup mode, it's in closed loop operation - ignoring all temperature (except the coolant sensor) and emissions data. Check the airbox, make sure you connected everything back up, check real careful like. I know the S38 has an air temperature sensor on the airbox.
Also, before it revs up to 3500, rev it up a bit, does it run fine, doesn't choke or anything?
Old 08-08-2006, 08:16 AM   #10
Darkness95m3
The software was developed for my vehicle.
Never had any issues with the software.
Old 08-08-2006, 08:20 AM   #11
Darkness95m3
The car runs fine, no hesitation or sputter.
It idles @1250rpm after running for a few minutes it just jumps to 3500rpm and stays there until I shut it down.
There is no check engine light at all until she starts to rev up to 3500rpm, then the check engine light comes on with code 1216 “Throttle Position Sensor”
Old 08-08-2006, 08:35 PM   #12
BigD
the misanthropist
BigD's Avatar
Weird, almost sounds like you fried something in the computer. Are you positive your throttle is closing? Open the hood and move the butterfly. You should hear a click as it goes on/off idle, and same at wide open. A non-existent idle position of the TPS would explain what you're seeing. The jump is, as I said, the engine exiting warmup mode and listening to its sensors, and adjusting the mixture, resulting in higher rpm for the off-idle throttle position.
Old 08-09-2006, 08:31 AM   #13
Darkness95m3
I'm removing the manifold off again tonight to have another look.
Will have a closer look at the ICV motor.
The other weird that's coming on is that the ABS light is blinking when I pump the brakes.
I just love electronics.
Old 08-29-2006, 06:40 PM   #14
bikemx423
Bayern Motor Werks
Send a message via AIM to bikemx423
Idle control valve. Take it apart... Check it, lube it all... Move it around... Put it all back together... Might help. If not, its the computer
bikemx423 is offline   Reply With Quote
Old 08-29-2006, 11:45 PM   #15
Proliphic
Trying to stay on 4wheels
Proliphic's Avatar
Send a message via MSN to Proliphic
take it to RMP..... problem solved.
Granite Silver '92 325i
Mark D (93) Chip
Motronix CAI
(Magic Fairy Dust )
Strut Brace
APEX Sport Springs
18" M3 CSL look-a-like's
Clear Corners All Around
6000K HID's
Thinline Angel Eyes
2.
Black/Silver 2000 Suzuki Hayabusa GSX1300R
8000K HID's
Clear Signals
(More to come)
Proliphic is offline   Reply With Quote
