Old 11-13-2017, 01:57 AM   #1
ezmaz
E39 No Power Steering when Extremely Cold
This last Friday was very, very cold in Toronto. My 03 530i had been parked outside all day while I was at work. In the evening when I started her up, I made sure to let it warm up for a solid 5 minutes. When I went to reverse out of the parking spot I had no power steering. I parked the car, left it running, checked the reservoir. The level was decent, slightly low but again, car was running. Closed the hood and got back in, ready to drive off without power steering and planning to take her in to get looked at, but as I drove off, magically, the power steering came back. The next morning when I was leaving for work, again, very stiff on start up, but after a bit of driving, went back to normal.
Thoughts? Opinions? Comments?
ezmaz is offline   Reply With Quote
Old 11-13-2017, 02:07 AM   #2
Change the PS fluid reservoir, it has a filter inside, and the fluid. If no change might need a pump.
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 11-13-2017, 06:31 PM   #3
PatrolOne
Also check the lower steering column universal joint. if it gets contaminated (which it often does on old cars), it can freeze up in cold weather and it will feel like the PS isn't working. Flush with a can of WD40...
PatrolOne is offline   Reply With Quote
