Old 03-25-2009, 10:15 PM   #1
///eP
Xbox live users
Ok, so i just got live for my bday, excited to get online, so i buy an ethernet cable to connect me directly to the router. turn the xbox on, and it will not connect, when testing it says it cannot connect to the ip address, i am not computer savy, so i dont understand what is going on. Im using rogers as my service provider, any suggesions ideas?? please let me know
thanks
///eP is offline   Reply With Quote
Old 03-25-2009, 10:29 PM   #2
sirex
King Sirex
could be that your router is set to give a static IP address, rathen then set one automatically for every new connection.. So that might be stopping it from obtaining an ip address for the internal network....
if u have your networking software for your router you need to perhaps install it onto your computer and log into and check the options. Also if you know the router you have you can type its IP address in internet explorer address bar and log in from there...
Old 03-25-2009, 10:57 PM   #3
ZHP_Bimmer05
Photographer/DJ/Engineer
Send a message via MSN to ZHP_Bimmer05
call technical support they can help, also try unlpugging the router and modem for 30 secs, to help reconnect the connection. then try.
2004 Mazda RX8 GT: 6spd VR
ZHP_Bimmer05 is offline   Reply With Quote
Old 03-25-2009, 11:01 PM   #4
///eP
tried that, nothing happened, would it matter that my router is for a mac?? im going to have to call rogers in the morning
Old 03-26-2009, 08:18 AM   #5
2K6E60
I found that if you use a HUB after the router it works better for some reason. Try that.
2K6E60 is offline   Reply With Quote
Old 03-26-2009, 09:16 AM   #6
2slow2race
2slow2race's Avatar
i was gonna start a thread on this same topic recently.
i was wondering what i need to buy to hook up my xbox live.
a router, hub or switch? whats the difference? is it plug and play?
me lost.
2slow2race is offline   Reply With Quote
Old 03-26-2009, 10:48 AM   #7
sirex
King Sirex
Basically theres a few ways you can connect to the net.
A) Your PC directly to your modem.
B) Your PC to Your Router, to your modem.
C) Your PC to a Switch, to your Router to your modem.
I dont think you can do Modem, Switch, PC/Multiple connections, because a switch doesn't assign IP addresses. So there would be collisions when trying to access the net.
A router differentiates the incoming connections because it assigns IP addresses.
As far as my XBOX goes, I have the current setup on my home network:
Modem, Router, Xbox, PC, PC, SWITCH, PC, PC. It was all plug and play. Maybe someone can explain this in better detail..
Could be that its a Mac router? I dont know how that works.
Old 03-26-2009, 11:12 AM   #8
2slow2race
2slow2race's Avatar
i think im gonna use a router to set up my xbox and pc.
so its gonna be like sirex's. modem, router to xbox and pc.
just gotta buy a router now.
Old 03-26-2009, 12:51 PM   #9
damameke
Get a wireless router, like Linksys or Dlink
So, Rogers modem to wireless router and Xbox to a slot(LAN connection) in the wireless router and run PC and laptop with wireless adapter
I am still trying to run the Xbox live in wireless, hitting an issue right now, "cant obtain IP" but in a LAN Xbox live works..
Make sure you run your wireless with WEB encryptions..
Old 03-26-2009, 01:30 PM   #10
sirex
King Sirex
what benefit/problem solving would a wireless router do for anyone? he still wont be able to connect if his settings aren't right.
Old 03-26-2009, 02:38 PM   #11
2slow2race
2slow2race's Avatar
im not gonna go wireless with mine because i use my xbox on my computer screen so i will hard wire it. nothing better.
Old 03-26-2009, 04:44 PM   #12
carscoe
Astranaut
carscoe's Avatar
i have mine setup as such :
Modem-router
-pc
-360
-Ps3
and i haven't had a problem, i did have to reset the router to get it to assign separate IP's though
2008 Saturn Astra XR
carscoe is offline   Reply With Quote
Old 03-26-2009, 05:22 PM   #13
damameke
Benefit.. just trying the wireless connection
wireless router config is correct, so setting is correct too. i suspect its the external Xbox wireless adapter, connect via LAN works... too busy now to narrow down the issue...
