Old 09-21-2008, 12:18 PM   #1
Nguyen_E30
0011 0001 1000
e30 318is swap
whats the best bang for your buck swap for this car? and aproximate cost for everything.
Nguyen_E30 is offline   Reply With Quote
Old 09-21-2008, 12:18 PM   #2
Nguyen_E30
0011 0001 1000
thanks
Old 09-21-2008, 10:20 PM   #3
JazzM
It all depends on what your intentions are... The M42 is a very light motor and has DOHC with 4 valves per cylinder. Its a "light" version S14 used in the M3. The main benefit is that it makes the car very balanced and light weight. To keep that balance and add power ideally the best bet is a S14 swap.
Other alternatives are the M5x swaps but again it all depends on what you want to do with the car.
T.
T.
Old 09-22-2008, 03:44 AM   #4
Nguyen_E30
0011 0001 1000
i was looking for something along the lines of m20b25
Old 09-22-2008, 09:49 AM   #5
supernaught
supernaught's Avatar
m20b25s are cheap and common. Easy to work on but it will add a bit of weight. More power, ya, but not as much as if you turboed the 318.
Pretty easy swap tho, I'd think.
supernaught is online now   Reply With Quote
Old 09-22-2008, 11:17 AM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
M20 swap is not worth it.
Old 09-22-2008, 02:26 PM   #7
e30_kid89
The Afro-stig
e30_kid89's Avatar
2-2.5kish out the door for an m50 swap.
Old 09-26-2008, 10:59 AM   #8
richie_s999
keep the m42!!!! Get an aluminum fly wheel, the stock one wheighs 28lbs, also look into getting other accesorries off the motor, an electric fan, manual steering conversion, and no a/c free up alot of power on the M42. if you lighten the load, get a proper cold air set up, chip it and get the cams adjusted your laughing, and the car will handle better with the 4 cyl!!!!!!
