Old 01-29-2006, 02:44 PM   #1
rendered
UGH! My car doesn't feel the same after getting it back. Question about final drive!?
My 330ci ZHP (M performance package) comes with a final drive ratio of 3.07:1 (instead of 2.91:1 of stock 330i/330ci/330cic).
The dealer changed my diff assymbly/final drive because of a bad noise I noticed after letting off the throttle at any speed.
The noise seems to be gone now, but the car feels slower and takes longer to respond. Like I have to bring the rpm's higher before it wants to pull hard. I just feels less responsive for some odd reason.
I think they replaced the final drive with the wrong ratio! I'm guessing they put in the normal 330ci 2.91:1 ratio instead of the correct 3.07:1.
Do you think this could be the cause?
rendered is offline   Reply With Quote
Old 01-29-2006, 02:46 PM   #2
jeremy
get underneath and look.. there should be a metal tag on it with the ratio stamped on it..
Old 01-29-2006, 02:59 PM   #3
BigD
the misanthropist
BigD's Avatar
Knowing dealer mechanics, who are only half-assed capable of performing only the most mundane tasks using typical components, I would be willing to bet that your guess is correct. Check your invoice first, make sure the p/n is for a 3.07. If that's fine, check under the car like Jeremy suggested.
Old 01-29-2006, 04:34 PM   #4
thinair
moderationistismingly
thinair's Avatar
you can also physically check my rotating the output flanges one revolution and seeing if the input shaft rotates more then 3 full revolutions (with the transmission in neutral)
Old 01-29-2006, 04:43 PM   #5
paul christians
87325is///MR.EVIL
^^^I was just going to say that....that sucks Mark....
87is325///2.7L..EVIL.....
Old 01-29-2006, 07:23 PM   #6
Primus
super blinger
Primus's Avatar
you would have to be pretty bang on the money to notice from 2:91 to 3:07's
theres not much difference there but hey, sounds like the case!
Primus is offline   Reply With Quote
Old 01-29-2006, 08:34 PM   #7
rendered
awesome! thanks guys! So when I bring it to RMP Rocco and I can put it on the hoist while doing my inspection and I can look for the metal stamp?
do you think its something I can ask the service manager I was dealing with?
by the way... Most problems they said they fixed, still are occuring. some worse than before
Old 01-29-2006, 08:35 PM   #8
STALKER
STALKER's Avatar
what dealer?
2008 AW/FR E90 M3
Old 01-29-2006, 08:38 PM   #9
rendered
I'll let you know when they fix everything to perfection.
Old 01-29-2006, 08:39 PM   #10
STALKER
STALKER's Avatar
Sorry, but what can of answer is that??????
2008 AW/FR E90 M3
Old 01-29-2006, 08:45 PM   #11
rendered
I'm sorry, I just don't want lurkers on the board causing shit for me before I settle this matter with the dealer.
Old 01-29-2006, 08:45 PM   #12
Lester
Lester's Avatar
Very noticable difference if you know your car
2006 Z4 M Coupe, Interlagos Blue
- Supersprint Race
- OE STB
- DZ CDVD
- RE CS
- H & R Sport Springs
Lester is offline   Reply With Quote
Old 01-29-2006, 09:22 PM   #13
rendered
thank you!
Old 01-29-2006, 09:50 PM   #14
Primus
super blinger
Primus's Avatar
i had 2:73's in my stang and put 3:08's in for the hell of it,
dropped my 1/4 time by .2 of a second, so really not a big difference
Old 01-30-2006, 12:54 AM   #15
RMPMOTORS
RMPMOTORS's Avatar
You can bring it by anytime and we can just lift it up to check for you..
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
