Old 05-18-2011, 01:26 PM   #1
front wheel hub
I need a new hub for the passenger front. Turner has them for 99$, but they look like the same chinese crap that's on ebay for 50$. Recommendations?
AFAIK bimmerspecialist and autopartsway dont have them.
Old 05-18-2011, 01:42 PM   #2
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Autopartsway should it's under a different name.
http://www.autopartsonlinecanada.com/
Wheel hub assembly 189.00.... for an e30. I know... expensive.
Old 05-18-2011, 01:48 PM   #3
The hub and wheel bearing is one assembly. Should be replaced together.
On autopartsway.ca it's listed under Brake Parts > Axle Hub Assembly
They call it a Front Axle Hub Assembly.
Old 05-18-2011, 02:23 PM   #4
dcramer
You should know there are two versions out there. One is 143mm(Meyle) one is 139mm(OEM). Performance friction hats don't fit over the 143mm one.
