Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 04-24-2006, 01:15 AM   #31
FLIPbmw
Can someone explain how I am suppose to hook up and ground to test the coils? I'm really confused with the bently manual and from what the original poster said. Am I suppose to remove the coils and then connect the probes to 4 and 15? (outer two, with 1 being in the middle). It says I need to ground it to 2? Very confused and I need help asap. I need my car for today so im heading out to get a multimeter once cdn tire opens (9.99 on sale, motomaster).
FLIPbmw is offline   Reply With Quote
Old 04-24-2006, 12:10 PM   #32
BennyL
7th Gear Member
BennyL's Avatar
wow... back from the dead! talk about reviving an OLD thread
but its good, since I've been meaning to ask also:
how many ignition coils in M44 engine? and should I check mine too? I'll be replacing my plugs soon, is that a good time to test coils?
Old 04-24-2006, 12:48 PM   #33
uber e36
uber e36's Avatar
In an e36, there is one ignition coil for each cylinder. I'm planning on replacing my plugs, so I should check the coils while I'm there...
Thanks!
'95 325is
'02 C4S
'17 C43
Old 04-24-2006, 11:08 PM   #34
FLIPbmw
ok I figured it out. My stock plugs were at .8-.9 and sometimes jumped to 1+ (but it might have been b/c my prongs were moving around). my Bosch replacements are reading at 1.0 and its consistent, pretty solid on that figure. My bad coils were going around 2.5+ a lot higher.
Positive goes to 15, negative goes to 1 for those ppl who arent sure. And you test it while the car is off, and the coil unlpluged.
Old 04-27-2006, 03:51 PM   #35
fletch
M50B20 Engine
Send a message via MSN to fletch
my E36 320i does the samething, my car only does that on cold start when temperature hits the middle and the bogging/jerking is gone? why? if it's a coil problem shouldn't be worse when the car got warm up?
but sure i'll definitely check the them because this problem is very annoying...and btw thanks for the GREAT thread!!!
fletch is offline   Reply With Quote
Old 04-27-2006, 04:01 PM   #36
keven
keven's Avatar
ye me 93 318i has the same problem have barely anypower i know its the coils and have ordered them but i ordered the coils themselves should i replace the bottom connector piece aswell? or will the ignition coils itself suffice
Hosted by Putfile.com
keven is offline   Reply With Quote
Old 04-27-2006, 04:08 PM   #37
fletch
M50B20 Engine
do i turn the car to "ignition" during the testing?
do i test the ignition coil harness connector or ignition coil itself? sorry i'm reading the manual but still got confused
Old 08-08-2019, 12:31 AM   #38
ultrasalBax
Send a message via ICQ to ultrasalBax Send a message via AIM to ultrasalBax Send a message via Yahoo to ultrasalBax
ultrasalBax is offline   Reply With Quote
Old 08-12-2019, 04:21 AM   #39
ultrasalBax
??????: ????????; ???: ????; ????????, ???: ; ???????, ?: ; ?*????? ???????, ?????: ; ?*????? ???????, ??: ; ??????????? ????, ?: ; ??? ???????: ???????????? ?????, ?????; ??????????, ?: ?; ?*?????? ?????, ??: ??; ???, ??: ; ?????????????? ???????? ????? ?????????????????? ???????????? ??? ?????????? ????????. ???????? ????? Kroll. ???????? ????? ????? MA ?????????? ? ?????????, ?????????? ? ???????????????????? ??????????. ?????????? ??? ??????? ??? ???, ??????????????? ?????? ??? ??????????? ????, ???????????? ????????, ????????????????? ??????? ??? ??????????, ?? ????????? ?????? ??? ???????, ?????????????? ???????? ?*?????? (????? ??.
????????????. ?*????? ?????????? ??? ???????? ????????? ???????????? ? ?????????. ???????? ?????? [K], ????????. .. ?*????? ? ??????? ??????? ????????? ???????? ??????????? ????? ? ???????? ???????, ?????????, ??????? ? ?. ?. PPT, PPTX ? PDF-????? ???????????? ?????? ? ???????. ?*?????????? ??????? ??????..
In air veils of Frico the Thermozone technology applies if in brief, then this maximum heat preservation at the minimum expenses of energy. But power consumption and thermal veil of frico adac090 power not only criteria of efficiency of air veils. Flow rate also affects efficiency. The concept of Thermozone does not ignore also this feature air veil Rasevyduvayet air under a certain corner for uniform protection of all aperture.
Old 08-12-2019, 04:43 AM   #40
ultrasalBax
?????????? ????????????**, ?????????? ???????, (?????), ??. ????????? ?????? ? ??????? ??????? ?????????? ?????. ** ??????? ?????????? ??????????? ??? ????????? / ?????? ?????????????????? ??????????? ? ???????????? ???????? ????????. ?*???????????? ????????-???????? ?????? ????? ???????????? ? ?????????? ????? ?????? ??????? ?? ???????????? ?????? ?? ???????????? ??????. ?????? ?????? ????????? ????????? ?????? ????? ?????????????? ??? ?????????? ????????????? ??? ??????????????? ???. ?????? ?????? ?????????? ?? ?????, ???????? ?????????? ???????, ??? ???????????? ???????? ?????? ?? ????????. ??????????? ???? ????? ? ??????? ??????? ?????????? ????? - ??????-????? RAL ??????? ????? - ????? RAL. ??? ???????????? ????????? ?? ????? ???????? ??????? ? ????? ???? ?? ???????? RAL ??? ???????????????. ? ???????? ?????????????? ????????? ? ????????????? ????????? ??????? ????? "???????" ???????????? ????????????????? ?????????? ??*?? ?? ??????????? ?????. ?????? ???????, ?????????? ? ????????? ? ????????????. ??? ?????? ?? ????????? ?????????? ??????????????????? ? ???????????? ?????????????? ? ?????? ????????????.
? ?????????? ??????? ????????????? ?????????? – Free Cooling – ? ??????? ???? ?????????????? ???????????? ???????? ??????????? ????? ? ???????????? ???????? ????????????. ??????? ?????????? ? ??????????? ????????? ????????. ?*????????? ??????? ???????? Free Cooling ?? ??????? ??????? ????????: ????????? ??????? ?????????? Free Cooling ?????????? ??????????????, ????? ??????????? ??????????? ??????? ?????????? ??? ? ???? ??????????? ????????????? ????, ????????, ??????????? ??????????? ????? ?, ? ??????????? ??????????? ??????? -? ?.
Old 08-14-2019, 01:55 AM   #41
ultrasalBax
???? ?????????? ??? ? ??????? ??????? ??????? ? ??????????????? ?????????????, ?? ?? ????? ???? ???????? (?? ?????????????? ? ?????? ???????). ?? ????? ? ????????????, ????????? ??????? ??????? ???????????. ? ?? ?????????! ????? ??????? air-o-swiss w2055? ??????? Cuckoo CAH???????? ?????? ?????????????, ???????? ???? ?????????: ??? ???????? ????????? ??????? ? ??????? ?????? ? ????????? ?? ????.
??? ?? ?????????? ????? ?????? ?? ??????????? ????????? ??? ?????? ? ????. ?*??????????????? ????????? ???????? ????????? ?????????? ???????- ????????, ?????, ?????? ??????? ??? ?????????? ?????????. ?? ?? ????? ??????????- ? ????? ??????? ???????? ????? ????? ??????, ??? ????? ?????? ?????????? ?????? ????????? ???????. ? ?????????? ?? ??????? ?????????? ? ????? ???????? ?????. ????????? ??????? ??????? ?? ???????????? ? ???????. ??????? ????????? ??????????? ? ???????????? ??????? ? ?????????, ????????? ? ?????. ??????? ?????????? ? ???????????? ?????????? ??????? ??????? ???????????? ?? ????? ????????????, ?????????????????? ? ??????????????? ???????????. ???????????? ?????????? ????????? ????????? ? ???????? ??? ??????????? ???? - ?????????? ? ??????????? ? ???? ????????. ????????????? ?????????? ????? ?????? ????????, ??????? ? ??????????? ??? ??????? ? ???????????? ?????????? ???????. ? ???????????? Newcli. ru ??????? ????????? ?????????, ????????? ????????? ? ????????? ??????????. ?????? ?????????? (???????? ?????? ? ?? ?????? ?????????) ???????????? ????? ?????????????, ???????? - ?????????????? ??????????, ?????????? ???????, ???????? ? ??? ?????.
?????? ??????????: ????????? ??????? CDF ??????????? ????????? ????????? ??? ????????????? ??????????? ? ???????????. ??? ????????? CDF???????????? ????????????? ??????? (?????). ??????????? ??????? ??????????? ??? ???? ??????? ?????????? CDF °C. ??? ????? ?????? ??????????? ??????? ?????????? ???????? ?????????. ????????? ????????? ??????? ??? ????????? Dantherm CDP CDP CDP. ????????? ????????? ??? ???????? ??????? ??? ?????????, ???, ????. ?????? — ??????????? ? ?? ??????: ????????? CDP ??? ????????? ??????? ?????????? ? ????? ???????? ?????????, ???? ??? ????????? ???????? ??? ????? ??????.
? ???????????? ???????????? ???????????? ????????? ??????????????, ????? ??? Aurora, Ballu, Venterra, Volkano, ??*?. ?*???????????? ???????? ????? master ????? - ???, ???????????? ??? ????, ???????????? ????????????? , ?????? ???????????? ? ????????? ?? ?*?????.
??????? ??????; ??????????? ??? ???????? ????, ?????, ?????????, ????; ?????, ?????????, ???? ? ?????? ??????????????? ?????????; ????????; ?????????; ???????????; ??????????; ????????????; ?*???????????? ??????????? ??????????. ??????????????????? ?????? ???????? ?????? ???????? ?????? ???????????, ? ?????????? ???????? ???????? ??????? ???????????????? ?????????? ??? ?????? ??????? ?????????? ?????? ????? ?????????????. ?????? ???????? ??????????? ??????, ??????? ???????? ? ???? ???????? ??????, ??? ????????? ?????? ???????? ????????? ??????????? ? ????? ????????, ???????? ????????? ?????????????? ???????????. ??? ?? ??????? ?????????? ?????? ?? ?????? ? ?????? ????????????? ??? ????????????? ??????????, ?? ????? ? ????????? ? ????? ?????? ??? ??????, ?? ???????????? ?????, ??????????????? ?????? ? ?. ?. ??? ????????? ????? ????? Wing ?? ?????? ?????????? ???????? VTS , ????? ????????, ??? ??????????????????? ?????? ???????? ??????? ???????? ?? ???????????? ?????, ? ??????? ?? ????? ????????????? ????????.
?????? ?????? ???????????? ????? ?????????????? ?????????, ???????, ?????? ?? ????????????? ??????, ???????? ??????, ?????????????? ?????????? ???????? ?????? ????????? ? ??????? ??? ?????? ??? ir ?????. . .
