Old 11-01-2007, 12:53 AM   #1
Trekz
Battery Light on
Alright so coming back from bimmercruise this year, my drive belt snaped, on the highway. After that i bough a new belt and put it on, after driving around for a bit i noticed the battery light kept turning on and off every once in a while. Then i did a engine swap, and now the battery light is still on. What could be causing it lol
Old 11-01-2007, 07:37 AM   #2
soon2b-e
did you re-use the old alternator ? that could be your culprit, or a loose battery/alternator connection, try checking those spots first
1995 325i- slushbox, cause i like it that way...
Soon2B- ??? - manual/stick cause i like it that way ?
soon2b-e is offline   Reply With Quote
Old 11-01-2007, 10:38 AM   #3
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
battery could use a charge?
Old 11-01-2007, 11:02 AM   #4
Trekz
yes i did use the old alternator lol, cuz i wasnt sure if the one of the newer motor worked. And no its not cus the battery could use a charge, i had batteries die on me before and the light didnt come on.
Old 11-01-2007, 11:40 AM   #5
myndgone
..... kLaSSe~1 .....
myndgone's Avatar
Send a message via MSN to myndgone
bad/loose ground somewhere?....same thing happened on my dad's car...
myndgone is offline   Reply With Quote
Old 11-01-2007, 12:14 PM   #6
JUS_CRZN
My other car's a jet.
JUS_CRZN's Avatar
Whats the batt voltage with the car running? It should be around 13.5-14.5 Volts.
JUS_CRZN
JUS_CRZN is offline   Reply With Quote
Old 11-01-2007, 03:09 PM   #7
its your voltage regulator. 2 screws on the back of your alternator, 40$ at the dealer. If you know how to take your alternator out, you can do it yourself.
Old 11-01-2007, 05:21 PM   #8
vadim321go
vadim321go's Avatar
i didnt even know we have a battery light, what does it look like?
Proud owner of a 95 325i
vadim321go is offline   Reply With Quote
Old 11-01-2007, 05:23 PM   #9
looks like a battery. its red, by the oil light.
When you rev your motor, does the light get dimmer?
if so, definately voltage regulator.
Old 11-02-2007, 12:05 AM   #10
Nascar318is
Nascar318is's Avatar
I had that problem, turned out my ground on my alt snapped.
Old 11-02-2007, 12:41 AM   #11
Trekz
if so, definitely voltage regulator.
yes it gets dimmer, how do i fix the voltage regulator, like what screw u talkin about, I ended up throwing in the other alternator that i had from the motor i swaped in, it looks horrible didnt even think it would work, but it works no battery light, but if its just 2 screw like you are saying then i would like to throw the old one back in it looks alot cleaner.
P.s i know how to change the alternator i did the engine swap myself, its my greatest accomplishment so far
Old 11-02-2007, 08:25 AM   #12
e30_kid89
The Afro-stig
e30_kid89's Avatar
If your alt. is shot I have one for dirt cheap. I just need to get it tested to make surei its good first.
Old 11-03-2007, 12:43 AM   #13
Trekz
i got a alt right now that works, that came one the 94 engine, but the whole plastic housing crap on the back off it is broken to shit so i took it off completely, and the one on my shot alt doesnt seem to fit on it. 92 alt was made in new Britain i think and the 94 one was made in France and they are different brands 92 is bosh 94 is V something lol
Old 11-03-2007, 04:29 PM   #14
Nascar318is
valeo, that's what I have on my 94. So is everything working now?
Old 11-03-2007, 06:49 PM   #15
Trekz
yah its workin now, but its missin the whole plastic housing thing with the tube.
