Old 07-19-2010, 12:06 PM   #1
tonyhavana
tonyhavana's Avatar
Stretched tires on rims...question
What are the performance advantages of stretching skinny tires on wide rims?
Thx
tonyhavana is offline   Reply With Quote
Old 07-19-2010, 12:30 PM   #2
5style
Hatters gon Hatt
5style's Avatar
none other then fitting rims that might not normally fit
Old 07-19-2010, 12:39 PM   #3
Steve30
Techno Viking
Steve30's Avatar
it actually hinders performance big time.
E36 ///M3 S54
STock 335i "The Punisher"
Old 07-19-2010, 12:46 PM   #4
Chris de la Cruz
sex, drifting & punk rock
Send a message via MSN to Chris de la Cruz
For drifting, less sidewall flex and rollover which means a more predictable slide (usually when running shitty tires)
www.CSCS.ca
Chris de la Cruz is offline   Reply With Quote
Old 07-19-2010, 03:13 PM   #5
Big time eh? Can you give a reason?
Old 07-19-2010, 03:46 PM   #6
Steve30
Techno Viking
Steve30's Avatar
Well first of all running a narrow tire doesn't help with putting the power down to the ground. You are also putting a lot of stress on the other suspension components due to the extremely low profile and pressure of the tire. Also, if you have high performance suspension, the car will jump over bumps on the road or track (again due to the inflation pressure). I'm sure there are more reasons. The only way I see them as being advantageous is in drifting as Chris mentioned earlier. I'm not hating on the look because I do think it looks killer with the right combination.
E36 ///M3 S54
Old 07-19-2010, 03:51 PM   #7
Michel
Michel's Avatar
^i think you'd also be more likely to bend a rim
Michel is online now   Reply With Quote
Old 07-19-2010, 03:58 PM   #8
Chris de la Cruz
^^^ ditto
www.CSCS.ca
Old 07-19-2010, 04:16 PM   #9
NOTORIOUS VR
NOTORIOUS VR's Avatar
Depends on how much stretch you're talking about. I've seen that OEM sizes on M3's they come with slight stretch.
That said too much stretch is gay.
Old 07-19-2010, 05:22 PM   #10
325isStephen
Drifter
Most of what you said there does not only apply to stretched tires.
Anyone running a low profile will have those symptoms, and stretching does not mean you are running a low profile. For instance, my old wheels in my sig were running a 50 profile, which is not low at all.
Also inflation pressure only needs to be 35-40 psi. Alot of cars, especially newer ones run 35 psi stock. So its not that much more, if at all more.
Any low stiff suspension will perform well under the right conditions, it does not have anything to do with tire stretching, but as mentioned above it does have to do with tire profile.
Your right about running a skinny tire, but in all cases even though the tire is too skinny for the rim width, its still often wider then stock, therefore better for performance or atleast equal to what the car is stock.
As chris said its great for stiffening up the sidewall which is great for drifting, but can also be useful for road course, although not as much, generally a stiffer sidewall is good for racing to eliminate slop. I found my e30 with a 195/50 stretched on a 15x9 alot better handling then the stock 195/65r14's.
Stretching is great for street and drift, not that its bad for track, but your better off running a different set of wheels dedicated to track regardless of stretch or not. Running an R compound on the street costs a fair bit of money if you daily a car.
325isStephen is offline   Reply With Quote
Old 07-19-2010, 05:45 PM   #11
spoony_prelude
Eurowerke
spoony_prelude's Avatar
here we go..... where do you people hear this shit?
2011 M3 coupe/moonstone/fox red
Old 07-19-2010, 06:01 PM   #12
325isStephen
Drifter
People get so mislead by people who don't know what they are talking about.
Just like the people who think stretched tires are unsafe
The reason people always think that is because of the sidewalls blowing out DUE TO LOW TIRE PRESSURE This happens because when you have a low profile tire, stretched or not it is very hard to tell when a tire is low on air. ANY tire that is low on air can cause a sidewall blow out.
Old 07-20-2010, 12:27 AM   #13
ZiMMie
Stretch tires What?
They "DO WORK" on the track too
ZiMMie is offline   Reply With Quote
Old 07-20-2010, 01:55 AM   #14
lukeh
runnin' capless
like stickers, the more stretch, the more horsepower.
lukeh is offline   Reply With Quote
Old 07-20-2010, 06:55 AM   #15
prince1
on to the next 1
prince1's Avatar
Send a message via MSN to prince1
ahahaha
LOL
Originally Posted by TNation View Post
Yo man, I got $6000 in my bank account, and I could buy any car i want
Ya man with $6000 in the bank, you're really balling arnt ya
prince1 is offline   Reply With Quote
