Old 07-23-2015, 10:23 AM   #1
MrMopar
2002 325Xi rear driveshaft help
hi guys,
I have a 2002 325IX 5spd w 297k kms that has picked up a vibration between 30-40km/hr when under load. It disappears completely above that speed. My shop said it is my rear driveshaft They quoted me $1500 for a new OEM one and $500 for a used one.
Where in Canada should I buy a new / reman unit ? I have built many cars and engines over the years, but no BMWs. Is this a backyard job ? Do I also order / replace the 'flex disc' or 'Guibo' as well ?
thanks in advance !
Trevor
MrMopar is offline   Reply With Quote
Old 07-23-2015, 01:20 PM   #2
cirrusblau
You can definitely do better than $1500. Is the used a remanufactured, or just straight out of another car?
I'm sure there are some places in Canada that you could get a remanufactured driveshaft from, but unfortunately I don't know of any myself. Pelican Parts in California sells a remanufactured one for $520 USD + core. It might not be practical with shipping and duty to get it from them, but at least it's an idea of the price.
I can't speak for the E46 or the AWD, but on my RWD E30, the driveshaft was a simple job. While you're in there, definitely do the flexdisc and definitely consider the shifter bushings. I don't know if the exhaust is in the way, but if it is, you'll likely need to cut the fasteners and put in new ones. They tend to be seized.
Hopefully that gives you a little bit of an idea of where to start
Old 07-23-2015, 01:23 PM   #3
cirrusblau
And I should ask... What's the mileage on the driveshaft? Is it actually bad?
My E30 had a broken down flex disk causing vibration, and another instance of vibration was caused by one transmission mount unbolting, letting the rear corner dangle. My u-joints were really really loose and yet it held up fine. AFAIK, the drivetrain of the E46 is virtually the same as the E30.
Old 07-24-2015, 01:26 AM   #4
jabela
I'm curious as to how they know the vibration is from the driveshaft. It could also be wheels, worn suspension/diff bushings, worn transmission or engine mounts.
A driveshaft vibration would most likely be RPM dependent, not vehicle speed. So you should feel at at the same RPM in each gear.
www.maisonapothecare.ca
Old 07-24-2015, 10:04 AM   #5
cirrusblau
That's completely false. Driveshaft is always turning with the wheels at a speed proportional to the wheels. A driveshaft vibration will be dependent on vehicle speed. You will feel the vibration at a particular road speed, and often multiples thereof.
There's already an abundance of false information on the internet. Please don't add to it.
Old 07-24-2015, 11:16 AM   #6
jabela
lol.. oh shit.. you're right. Don't know what I was smoking last night. Obviously anything past the transmission is vehicle speed dependent. Sorry for that derp!
Old 07-27-2015, 11:00 AM   #7
MrMopar
Thanks - the shaft is bad - play everywhere , centre bearing, u joints. The shaft has 290k kms on it. I will keep shopping for a reman unit I guess.
Trevor
