Selling a used set (Front and Rear) red color ST-40 StopTech big brake kit for the E46 M3 (
https://www.turnermotorsport.com/BMW...=50&Ntt=340032) These are off a race car and are dirty but work perfectly fine. If you want bling, you have 2 options: I give you an Oral-B tooth brush and you can clean them, or go and buy a new set.
These are forged 2-piece slotted 355x32 AeroRotors with curved airfoil-shaped vanes for optimal cooling. ALL the new and used rotors noted below have been cryo?d for at least double the longevity. StopTech have the best pad changing mechanism with no need to remove the caliper.
Kits come with cryogenic treated rotors, hats, calipers, mounting brackets, stainless steel braided lines and all hardware (although it?s always a good idea to use new hardware).
Both front calipers were rebuilt last month with new boots and seals (kit from Performance Brakes -
https://racingbrake.com/st-65bs ) .
Kits come with extra cryo treated rotors, hats and Hawk pads. This is what you get:
Front & rear kits of calipers,
cryo?d rotors, hats, mounting brackets, stainless steel braded lines and hardware.
Extra set of used front cryo?d rotors with hats.
Extra set of used rear cryo?d rotors.
Extra set of StopTech 355x32
cryo?d rotors new in a box with anti-rattle mounting hardware ($900 value)
3 sets of Hawk DT-60 pads
new in a box ($1100 value).
1 set of Hawk DT-30 pads
new in a box ($350 value).
Used sets of DT-30 and DT-60 pads (approx 60% pads remaining).
$4500 for the entire lot
416-728-5615
