Old 10-05-2015, 01:38 PM   #1
anth
E46 M54 Oil Pump Nut
Hey guys, just completed my first ADS weekend and had an absolute blast.
My car is a 330ci ZHP and it would regularly be over 6k rpm on the back straight at Mosport each lap.
I've read about the oil pump nut stuff but a lot of those threads are ancient and none mentioned a conclusive/reasonable solution at the time. Just wanted to check with some of you guys to see if anyone has taken measures against this, what exactly you did/costs involved, and really how much of an issue you think this is.
FWIW, my car has 123k on it, is a 6/2005 build date and has no track time on it /very limited time north of 6k rpm aside from this weekend (and even this weekend was only a few seconds per lap.
Also - the car is stock aside from a CAI mainly for sound. Any ideas for good value-oriented upgrades? So far I'm just aiming for more seat time, upgraded pads/rotors when needed, same w/ tires and if I come across a good deal on lighter wheels and a front strut brace, then that sounds like a good idea to me too.
Thanks in advance!
anth is offline   Reply With Quote
Old 10-16-2015, 12:04 PM   #2
LVP
My recommendation for tracked cars is to drop the pan, baffle it (helps prevent oil starvation, Bimmerworld sells), secure the nut (Bimmerworld also sells a pre-drilled but with safety wire), reinforce the subframe (I like Turner's kit better), and do the pan gasket. You want to go in once and do all the steps then. I put 350,000km on my E36 328i and never had an issue.
LVP is offline   Reply With Quote
Old 10-23-2015, 02:49 PM   #3
jabela
Here's your ultimate solution for the oil pump nut
http://store.bimmerworld.com/gsr-m52...aft-p2210.aspx
GSR's M52/M54 Four Bolt Oil Pump Shaft replaces the failure-prone single-nut OEM sprocket retaining system on the M52/M54 engine. The replacement shaft is precision ground, machined, and hardened for superior wear characteristics and resistance to shear failure. The four-bolt mounting system prevents the pump nut from becoming loose and backing off. This package is far superior to welded or safety-wired versions of stock parts, or a single-fastener replacement.
Kit includes new pump shaft, sprocket, and inner rotor. Fully assembled - no pressing required.
www.maisonapothecare.ca
