Old 03-02-2015, 11:01 AM   #1
Romanowski
Clean E46 M3 CB/IR
Je parle francais aussi**
2001 E46 M3
160,000 kms
Carbon black exterior with a rare Imola Red interior
***VANOS inpected, Subframe reinforced, Rod bearings recall done****
These things are a MUST on these cars.
Mods:
-Rogue Engineering El Diablo Muffler ( sounds so good )
-AFE stage 2 Cold air intake
-CSL Style rear diffuser
-CSL style carbon fiber splitters
-Blacked out Front grills, side grills, side markers, corners.
-15% tint all around
-Dice Ipod Kit
-I have a set of UMNITZA V2 angel eyes that I have not yet installed also
The maintenance I have done in the past year ( all receipts on hand)
Subframe mounts reinforcement
New rear tires
Exhaust hangers
Alignment
Oil change less than 200kms ago
Here is the maintenance from the previous owner
2013: ( at 149,000 kms)
entire power steering system
Power steering fluid flush
Brake fluid flush
Rad fluid flush
Dustless break pads front
mashined rotors
new battery
2011: ( 140,000 kms)
Rear dif fluid change
tranny fluid change
Valve adjustment
Bully clutch (flywheel,pressure plate,clutch disk)+ throwout bearing+ shifter bushings
driveshaft center bearing
guibo
Differential seals
fuel filter
cabin filter
front tie rods and outer ball joints
As you can see, no money was spared/saved on maintenance ( which is why I bought the car).The only negatives on the car are on the exterior... it has some stone chips and a few scratches. Nothing out of the ordinary.
My price is $18000, I am open to REASONABLE offers. We can even work something out if I take off the after market parts. No joy rides *** If you are serious and you give me a deposit, I will let you drive.
Romanowski is offline   Reply With Quote
Old 03-02-2015, 11:08 AM   #2
Romanowski
pics
http://imgur.com/LnmoIfL
http://imgur.com/gxUuQnA
http://imgur.com/SPYr22G
http://imgur.com/bN5WFFo
Old 03-11-2015, 11:45 AM   #3
Romanowski
Bump!! All PMs answered!
Old 03-22-2015, 01:27 PM   #4
Romanowski
Bump
Old 03-29-2015, 06:19 PM   #5
Romanowski
Bump
Old 04-11-2015, 05:52 PM   #6
Romanowski
*sold*
