Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 12-11-2010, 01:47 PM   #211
canuckder
canuckder's Avatar
Atleast there was some thought put into it,
Ive seen some hack job heat shields
canuckder is offline   Reply With Quote
Old 12-11-2010, 10:05 PM   #212
Haha thanks.
It's simple and will do as a good of a job as anything you can buy.
Old 12-14-2010, 01:16 AM   #213
Ordered these tonight. I just made the XMas sale by 12:00 whew. Bimmerworld TrackCAB's for $99!
Wheel studs from Bimmerworld were only $100 as well.
Old 12-14-2010, 08:23 AM   #214
richie_s999
Nice sale! Are they doing a boxing day sale?
Old 12-15-2010, 06:46 PM   #215
the oem rads are ticking time bombs especially on a track car imo...
id also do the sway bar reinforcements.(id do all of them) but obviously its up to you.
some people even like to box in the rear subframe a bit...
Old 12-15-2010, 06:54 PM   #216
LOL n00b.
Old 12-15-2010, 08:15 PM   #217
thatguy
lol.
thatguy is offline   Reply With Quote
Old 12-15-2010, 10:39 PM   #218
exbmwtech
How about reinforcing the trailing arm pocket area?(think about the tires you are going to use)
How about adding a few more bars to the cage/sub frame to reduce flex ( I've read the BMWCCA rules..... but if are mostly going to run gt sprints/gt challenge in Ontario.... make the cage safe and stiff .......first ....less headaches later.)
exbmwtech is offline   Reply With Quote
Old 12-16-2010, 01:02 AM   #219
OEM Rads are good. Not sure where you're getting the ticking time bomb idea from. I've had the same rad for 3 years on my DD which has seen A LOT of the track. No issues. As I've only had it 3 years, who knows how old it really is.
Sure maybe if it were over 6 years old then I'd start to worry. But at that age, isn't any rad on it way out?
As for the swaybar reinforcements, I still don't find it necessary especially when I'm going to be running a stock rear swaybar if I run one at all.
The trailing arm pocket definitely needs to be done! Turner recommends just welding around the original mount. No need for the extra plates. I'll have that done when the cage is done since I can't weld
The cage is pretty final in case I want the sell the car.
Old 12-16-2010, 01:12 AM   #220
Alright big update!
Here we go:
Turner Motorsport Trailing Arm Bearings installed:
Aluminum Sub frame Mounts Pressed:
Old Upper/Inner Control Arm Bushing pushed out and fancy new Turner Motorsport Monoball mounts in:
Everything assembled once again:
Solid everywhere
Last thing for the rear end is the 3.73 LSD and some Lower Control Arms.
Old 12-16-2010, 02:52 AM   #221
nice update.
as I said its up to you as to what you are going to do. people can lol all they want.Nothing I suggested is out in left field. I figured you would want to do everything at this stage instead of having to fix it later on.
underside of the car is pristine for a car from this area.
did you weld the rtab pocket reinforcements?(edit: just read you havent yet)
the car is gonna scoot when its done!
Old 12-16-2010, 10:24 AM   #222
nice update.
The car is from New Jersey
Old 12-16-2010, 12:31 PM   #223
Those trailing arm bearings are sexxyyyyy
Old 12-16-2010, 02:13 PM   #224
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
<3 this build.
Stanceiseverything.com
Old 12-16-2010, 02:35 PM   #225
nice update.
All you do is repeat shit you read on the internet, you have very little real world experience.
Kurt knows what he's doing and isn't just replacing shit because some guy on the internet has it's uncles brothers friends fail or something that magically makes everyones car a ticking time bomb.
It's smart and better to just know what you are doing than repeat what you read online.
If the rad fails, i'm sure Kurt will replace it, probably with equally as good if not something better.
