Old 03-02-2004, 01:41 PM   #1
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
Unhappy Water leaking in the trunk? or My trunk smells like moldy snatch? (My first write up)
Oh are you in for some fun now
Sorry I didn't take any pictures but I wasn't thinking of doing a write-up at the time until qimis needed it so I am posting this for everyone.
My car is in MINT condition and I had a shitload of rotting in the trunk area. It kept getting wet for some reason and the trunk hood kept getting condensation every day. I thought that it was the trunk lid leaking until I pulled out the carpeting. One day last week, I installed a stereo and decided to rip out the carpet to clean the metal inside the trunk. To my surprise I found about 3 holes I could fit a golf ball thru.
What to do is go to Crappy tire and buy woven fiberglass and liquid resin. If you have never fiber glassed anything then tell me and I can direct you how.
Pull out your carpeting on the trunk floor and walls. While your at it you might want to clean your carpets and spray the inside trunk with Lysol (to get rid of that nasty moldy snatch smell. )
You will find the trunk rotted near the back of your rear wheel wells. The most common side is where the car jack is because it is lower then the passenger side. The problem is that stones from the tires hit the trunk pan and wear away at the undercoating and eventually rot the trunk pan.
You will also have to remove your battery and the plastic battery tray to get underneath it. TRUST ME you’ll want to do this. I found ½” of old nasty shitty crappy moldy stuff that was kicked up from the tires into the trunk along with another hole.
First take a screw driver and break out all the rotted metal until you reach solid steel. You will find that a .5" hole will end up to be 3" long. Then using 80 grit sandpaper and a file, remove all the shit around the hole so you will be fiber glassing bare steel. Use a wire brush to remove rust from the hard to reach places. Clean all the crap out with a garden hose and let it dry.
Cut your fiberglass matting in sections to overlap the holes at least 3/4". I used about 4 layers of fiberglass to fill the holes. Before I laid the fg over the holes, I spread some resin around the hole, on the thickness of the steel and around the hole even on the outside of the car around the hole. I laid one layer of fg on the hole from the outside of the car wheel well to prevent water from further rotting the hole.
Like magic, you won't have any more water leaks.
Damn all this talk about holes, going to the gf's house to get me some action tonight
Agent BMW trailer
Adriano is offline   Reply With Quote
Old 03-02-2004, 09:34 PM   #2
NickP
NickP's Avatar
Also on e30's tail light gaskets leak like you wouldn't believe - this is what may have caused some of the holes in the first place.
Old 04-19-2004, 02:06 AM   #3
qimis
Mr. Euro E30
qimis's Avatar
me and adriano was working on my trunk yesterday. you wouldn't believe there was a lake with all super nasty stuff underneath there. first i cleaned up all the rust w/ wire brush, sand paper, anything that can clean up that nasty thing. then clean the 'lake' after. adriano helped me putting the fibreglass in, although we got high for an hour or so (freakin resin ... ). it came out really good after that, no more water coming in to the trunk (hopefully ... )
and here's a couple pics from yesterday and today
qimis is offline   Reply With Quote
Old 04-19-2004, 02:08 AM   #4
qimis
Mr. Euro E30
qimis's Avatar
ready to be patched w/ fibre glass ...
Old 04-19-2004, 02:09 AM   #5
qimis
Mr. Euro E30
qimis's Avatar
a bit of resin, hardener, fibre glass ... done !
Old 04-19-2004, 02:09 AM   #6
o man i better check mine...
Old 04-19-2004, 02:10 AM   #7
qimis
Mr. Euro E30
qimis's Avatar
adriano's car wearing a wedding gown
Old 04-19-2004, 02:11 AM   #8
qimis
Mr. Euro E30
qimis's Avatar
ready to eat you !
Old 04-19-2004, 02:13 AM   #9
qimis
Mr. Euro E30
qimis's Avatar
BOOOOO !
Old 04-19-2004, 02:15 AM   #10
qimis
Mr. Euro E30
qimis's Avatar
alpine white
Old 04-19-2004, 02:15 AM   #11
qimis
Mr. Euro E30
qimis's Avatar
rear bumper's in for good
Old 04-19-2004, 02:16 AM   #12
qimis
Mr. Euro E30
qimis's Avatar
al's going euro w/ his rear tires
Old 04-19-2004, 02:17 AM   #13
qimis
Mr. Euro E30
qimis's Avatar
sexy
Old 04-19-2004, 02:21 AM   #14
qimis
Mr. Euro E30
qimis's Avatar
today's mods:
- independent fog lights .
special thanks to adriano
Old 04-19-2004, 02:25 AM   #15
qimis
Mr. Euro E30
qimis's Avatar
i would recommend all of you that has E30, especially if the car is winter driven, should check this spot. this is a common problem on E30.
take out the trunk cover (mouse hair) on the sides, and see if there's any rusts / not. there's also a plastic cover besides the battery, where the hole in my trunk was, you might wanna take out the plastic ( it has a little clip attached ).
