Old 04-03-2007, 10:22 PM   #1
STALKER
STALKER's Avatar
Send a message via MSN to STALKER
Jeff Werkstatt Detailing products.
Just ordered a few things from their site.
Anyone else use his products? I love Klasse and heard this stuff is even better.
Any tips for application and removal?
2008 AW/FR E90 M3
//RAC RG63//Volk TE37//AP Racing BBK//Akrapovic Exhaust//Dinan SW//Dinan Intake//JRZ RS1 Coilovers//Dinan Monoball Control Arm Bearings//VRS Diffuser//
STALKER is offline   Reply With Quote
Old 04-05-2007, 04:32 PM   #2
BMWWW
Courtesy of Changeling.
Thank you for contacting the Werkstatt. We appreciate your interest in our
products.
We get quite a number of people switching from the Klasse products and have
yet to hear a single voice of regret. While those products are good and
perform well, we feel that the Werkstatt has taken the category to a new
level in terms of aesthetics (wetness and clarity of shine), in application
ease (with products like Trigger), in value, and in variety.
1. Yes. While we do not like to give specific timelines for longevity due
to the huge number of variables that can effect it, our products are amongst
the most durable available. Applied under the same conditions, Werkstatt
products will easily match anything in the market (short of a new
clearcoat!) and exceed the durability of the vast majority.
2. First, we do not test our products for compatibility with any other
manufacturers' products. When mixing and matching between product lines,
you may end up venturing into the territory of experimentation. That said,
the durability of the polymers used in our products do make them well suited
for this type of base-layer use. Once cured, we would not expect any
chemical interference by other products with the Werkstatt layers. There
are a few things to keep in mind in choosing what products to use as
topcoats. The goal is to be as gentle as possible on the lower layers
during application. To work well, topcoats need to be free of abrasives and
preferably have minimal amounts of stronger solvents.
We can't comment specifically on the #7 and 50/50 since we do not know their
specific formulaic structure, but as long as they meet these basic
requirements, they should not cause undue wear on Werkstatt base layers
during application.
One thing to keep in mind, however, is that you may just find all of these
topcoats un-necessary! The Werkstatt products alone provide an exceptional
finish. And while different than an oil glaze and carnauba finish, it may
actually be preferable. It is rather subjective.
3. Strictly speaking, the 2 products that would most directly compare to
AIO/SG are the Prime and Acrylic Jett formulas. These are the products that
would apply in the most similar manner and perform similar functions.
However, the Werkstatt does offer options that go beyond this.
On the Prime side, there are 3 specialty versions that may offer some added
characteristics that you find desirable. For instance, since your plan is
to top with carnauba wax, you might consider Prime Carnauba. It bonds the
highest grade of carnauba wax into the polymer base layer for increased
longevity of the natural wax.
On the Jett side, you may want to consider Acrylic Jett Trigger. This newer
3rd generation spray formula offers similar performance, longevity, and
aesthetics as the original AJ, but it's formula is tailored toward a
spray-and-buff application process. With no wait time before buffing, it
eliminates the possibility for hazing/streaking that can occur if AJ is
applied too thickly. Trigger started off as a special edition, but has
been so popular, it will become a permanent part of our line-up.
4. Directions for all of the products in question can be viewed on our
website. For the Primes, the process combines aspects of both a polish and
sealant: work the formula into the surface with a rubbing motion, allow to
dry (30 minutes or less), and buff off. The aim is to leave a very minimal
amount of residue on the surface after the application/polishing phase.
This will make buffing easiest. Prime is also suitable for application via
random orbital polisher. We recommend a polishing or finishing pad at
speeds of 4-5 (if using the PC RO machine). Prime cannot be layered, but a
second coat can ensure complete cleaning and uniform coverage. The Jetts
can be applied over Prime immediately.
For original Acrylic Jett, the process is similar, except there is no
polishing motion necessary since the product is purely protective. Using a
foam or microfiber applicator, spread a very thin coating over the surface.
It will dry very rapidly and can be buffed almost immediately. For easiest
results, only a very small amount of product needs to be used. If any
streaks or hazing develop that is difficult to buff off, we recommend
letting it cure for around 30 minutes and then going over the surface with
either a very slightly damp microfiber towel, a light coat of Acrylic Glos,
or an additional layer of AJ Trigger. Any of these options quickly
eliminate any streaking. AJ can be layered. We recommend waiting at least
30 minutes between layers.
And for AJ Trigger, the process is even simpler: spray a small amount on the
surface, spready it uniformly with a microfiber towel, and continue buffing
until the surface is clear. Flipping to a dry side of the towel on the
final pass will help leave perfect results. There is no waiting time
necessary. It is one continuous application/buffing process. Trigger can
also be layered, with 30 minutes recommended between layers.
When switching from these Werkstatt products to something from another
manufacturer, we still recommend waiting a full 24 hours to ensure complete
curing and best results. Many products could be used immediately, but as a
general recommendation, we err to the side of caution.
That was a lot of information to cover, and if you have any other questions
or need clarification, please do not hesitate to email us again or reply to
this message. We want every customer to have the best experience with our
products and obtain the best results!
Original link:
http://autopia.org/forum/detailing-p...effs+werkstatt
BMWWW is offline   Reply With Quote
Old 04-12-2007, 03:27 PM   #3
picus
Detailing Geek
Send a message via AIM to picus
I use prime and AJT on just about all the light colored cars I do. They work very much like AIO/SG, but Prime works a little better and is easier to use, and AJT of course is a spray (so much easier to use). Here is how I use them, Prime is the sort of "tricky" one.
If I am using prime as a chemical cleaner I apply with a white pad and polish like normal, for removing water spots, oxidation, etc. This is rare though, normally I am using it as a sealant base in which case I apply like this:
Apply a small dab (like really, really small, like dime size = way too big) to a black pad and apply via PC at speed 2-3. This will do one panel on the first application, and once the pad is primed it'll do 2 or even 3. Now, when you've gone over the panel once you'll see this white haze, which is the prime. Go over it again and make it go clear. White spots = spots that are going to be hard to remove. So go over it to thin it out. Repeat over car.
Immediately buff off using AJT and microfibers. AJT is totally painless to use. One spritz = one panel, spread, flip towel, buff off.
picus is offline   Reply With Quote
Old 04-12-2007, 05:19 PM   #4
STALKER
STALKER's Avatar
Thanks for the info.
2008 AW/FR E90 M3
