Old 03-01-2007, 11:59 PM   #1
EugeneBMW
BMW M POWER
Rims have black dots that wont come off. PLEASE ADVISE
After driving my M5 wihtout a wash for about 3 months, I found that there are black dots all over my front rims (mostly on the dish) that wont come off. What can I do or should I just re-finish them?.
http://www.seautocare.ca
http://www.seautobmw.com
M5...400HP...6Sp...$115,000
Full tank of gas....$70
M-hat...$45
Being the only M5 on the lot....PRICELESS
EugeneBMW is offline   Reply With Quote
Old 03-02-2007, 12:00 AM   #2
shimajer
loudddddd
same! anyone help us out
shimajer is offline   Reply With Quote
Old 03-02-2007, 04:53 PM   #3
David
They could be embedded brake dust or tar. In either case, clean your wheels very thoroughly with car wash soap and a sponge. Spray them down with a wheel cleaner prior to washing with soap if they are really bad.
Once clean, grab some clay and clay the wheels. If it's tar it will come off. If it's brake dust then it may not come out if it is pitted in the rim.
1997 318i
Boston Green Metallic with Beige cloth interior
15" Steel Wheels with Plastic Hubcaps
Administrator on DetailersClub.com
David is offline   Reply With Quote
Old 03-02-2007, 11:01 PM   #4
T-spec
T-spec's Avatar
It might just be corrosion. If you tried cleaning them well with wheel cleaner and it still doesn't help try this. I'm assuming the rims are bare aluminum either with a machined or polished finish. If you go to canadian tire, get a product called autosol, its an aluminum polish that comes in a tube. Get a bunch of clean rags and start rubbing, buff off excess polish with some clean cloths and your rims should look pretty dam close to new.
live fast, die quick, drive a bimmer
T-spec is offline   Reply With Quote
Old 03-02-2007, 11:41 PM   #5
ZiMMie
and if it doesnt?
#E36-S54 #CSLWannabe
Old 03-03-2007, 06:52 AM   #6
T-spec
T-spec's Avatar
Originally Posted by ZiMMie
and if it doesnt?
Then it sucks to be you! I had this same problem, used the "stuff" , now rims look great.
Old 03-03-2007, 04:42 PM   #7
use never-dull. partsource.
also, dont not wash your car for 3 months.
Old 03-03-2007, 10:29 PM   #8
EugeneBMW
BMW M POWER
I am going to try that....wheel polish might do the trick.
M-hat...$45
