Old 11-30-2006, 08:08 PM   #1
Yorkie
Yorkie's Avatar
Need power source
I need a power source that is triggered by the ignition for my Sirius receiver as the cig lighter is always on.
Any suggestions on an easy wire to find and tap?
Thanks.
Yorkie is offline   Reply With Quote
Old 11-30-2006, 08:31 PM   #2
Justin e36
Justin e36's Avatar
any hot wire you want will work, other than the OBC, cigarette lighter, and interior/glovebox lights. However, it depends on how much power your Sirius receiver draws, you might not want to tap into a circuit that is already under load and instead make a new circuit with a relay to turn it on when you turn your car stereo on.
If it draws little current, tap it into your stereo's 12v remote lead so it turns on when your car's stereo is on. If you want it on whenever your car is on, then tap into any of the window switches, and make sure to increase your fuse in the fusebox by 2.5V.
Old 11-30-2006, 11:43 PM   #3
paul christians
87325is///MR.EVIL
they draw as much as deck,so can take power from the same wire as your deck....
87is325///2.7L..EVIL.....
Old 12-01-2006, 07:09 AM   #4
Yorkie
Yorkie's Avatar
OK, thanks.
