Old 09-20-2006, 07:55 PM   #1
OEM rear wing
I have a 01 Coupe, and I've been trying to rid myself of the nasty OEM spoiler/wing (NOT the M3 style lip spoiler) on the trunk. I called the dealer and he said he isn't sure if the spoiler is stuck on with 3M adhesive or drilled. I thought it was surley drilled until hearing his words, so I went out and pried off the trunk lining under the turnk lid and couldn't see any signs of drilling
So I called 4 other GTA dealers and they all said it's adhesive (but a few seemed to be confusing it with the M3 style Lip Spoiler). Then I called a few well known Bodyshops they said it's bolted.... WTF IS IT?!!??!
Does anyone on here know for sure if it is either 3M adhesive or bolted?
Cheers!
Old 09-21-2006, 11:54 AM   #2
cisco911
Its bolts...why did you take the liner off??? The bolts would be right on the edge of the left and right side of the trunk.
Old 09-21-2006, 01:06 PM   #3
E46er
Yea the m3 spoiler is stuck with 3m...and the wing is bolts.
E46er is offline   Reply With Quote
Old 09-21-2006, 06:09 PM   #4
Update: after a few confirmations, there are NO bolts on my trunk (that's why I took the liner off to make sure there weren't any). The COUPE's rear wing is adhesive but the sedan's is bolted on. They are also visually different - if only slightly.
Cheers!
Old 09-21-2006, 08:27 PM   #5
cisco911
it doesn't make sense for a wing like that to be glued on...you could just yank it off!!!!
Old 09-21-2006, 09:16 PM   #6
It would take some SERIOUS yanking !!
A heat gun and dental floss would do the trick but then you have paint damage. Either way you're looking at a complete repaint
Old 09-22-2006, 10:09 AM   #7
kerisabe
Capturing the Impossible
kerisabe's Avatar
Mine was sticked on using adhesive. Got the bodyshop to take it out and repaint the whole trunk so it's perfect.
Owning 401 East.
kerisabe is offline   Reply With Quote
