05-15-2006, 05:36 PM
Car: 325i
s50 or s52 cams
is there any difference in power between the two sets of cams when putting into an M50? what chip would go the best with the cams?
05-15-2006, 08:39 PM
Car: e90 LCI 328i
You can only put the S50 cams into a M50, and likewise only S52 Cams in a M52.
You will need a chip though, I cant remember who sells them (Eurosport or Turner maybe?) or get something custom
2009 328i 6-spd - AW - Oyster Dakota - Sport Pkg. - Prem Pkg.
05-15-2006, 11:21 PM
Car: Z3, M3 (e36)
Why can't you put the S52 cams in a single vanos M50?
According to VAC and turner the S50/S52/M50/M52 single vanos North American motors all share the same camshaft design and the camshafts are interchangable. ( http://www.vacmotorsports.com/cgi-bi...pl?item_id=454)
T.
T.
05-15-2006, 11:57 PM
Car: 325i
yeah i thought both could be used in the m50 motor. i was just curious if there is any difference in using either or in the m50.
05-16-2006, 09:25 AM
Car: Z3, M3 (e36)
S50 and S52 cams are different lift and duration. I believe the S52 ones are more aggressive.
T.
T.
05-16-2006, 10:21 AM
Car: 325i
so with getting the s52 cams i could probably end up with better results in power
05-16-2006, 10:23 AM
Car: Z3, M3 (e36)
Yes, the goal with more aggressive cams is to give you more power on the top end.
T.
T.
05-16-2006, 12:42 PM
moderationistismingly
Car: 97 328is-02 Impreza
Actually the 3L cam will fit the 2.5L, 2.8L and 3.2L, but the 3.2l cam will only fit the 2.8L. Something to do with counterbalances no clearing the cam rack. Basically if you swap the cam rack with the cam, an S52 cam will fit in an M50 head.
And JazzM, I've heard the opposite, the S50 cam is slightly more aggresive.
05-16-2006, 07:58 PM
Car: e90 LCI 328i
Sorry if thats wrong information, but that is what Ive read from bf.c
seems like I almost had it
05-16-2006, 10:26 PM
#10
Car: Z3, M3 (e36)
Yeah looks like due to the counter balance the S52 cam will not clear the M50 cam rack. It also appears that the S52 cams are hollow as opposed to the S50 ones being solid.
Havn't seen any TIS numbers regarding lift and duration yet.
You can put the S50 cams in both the 2.5,2.8 and the 3.2.
T.
T.
