04-29-2006, 01:22 AM
#1
BMW again.
Car: 1994 325is
EGT probe location?
hey guys i wanted to know were you guys installed your EGT gauge probe? im hearing conflicting information , some say on the manifold , some say on the Y pipe. some say because you want to be as close to the engine as possible, and then some say you need to measure the temp over all 6 cylinders.
can someone shed some light?
04-29-2006, 10:07 AM
#2
Car: 95 Dodge Avenger
Tap your manifold on the 6th cylinder as that will be the first to run hotter/lean, since i'll assume the #1 cylinder gets hit with fuel first
...____
1 | __
2 | __
3 | __
4 | __
5 | __
6 |____
Sean
2008 Toyota Rav4 V6 AWD Sport - Daily Driver -
www.SpoolnU.com - ALPHA. SIGMA. BOOST.
04-29-2006, 06:09 PM
#3
Banned
Car: 74 tii, 93 M5x2, e90
...____
1 | __
2 | __
3 | __
4 | __
5 | __
6 |____
Now why would you assume that cylinder one gets "hit with fuel first" ????
MarkD
04-30-2006, 09:38 AM
#4
I've always been told that pressurized fluid of anysort will take the shortest path first.... that being said while driving any changes in pressure or pulse/fuel feed (by fuel management device) would most likely affect cylinder #1 first if the fuel rail is fed from that direction forward.
Sean
04-30-2006, 10:25 AM
#5
BMW again.
Car: 1994 325is
well from the advice i was given on bfc, they are saying basically that you want to be 1" from the cylinder head at cylinder 1.
04-30-2006, 11:08 PM
#6
moderationistismingly
Car: 97 328is-02 Impreza
Actually the fuel rail is connected to the fuel line at the back of the engine where Cyl #6. Also, why would it matter what end of the engine it starts with? If the fuel leans out it's going to be like 1000th of a second difference between the time the 1 and 6th go lean (or rich).
As far as the fuel rail pressure is concerned, I can't see it really mattering which cylinder you go with. There is going to be the same fuel pressure at injector #1 as #6. That's like saying there is more water pressure at a tap then at the end of a 100ft hose.
05-01-2006, 02:04 AM
#7
out of curiosity, where is the turbo flange most commonly mounted on the manifold for BMW installs? between the middle exhaust ports (3/4) or on near/far (1/6)? Would that not be the ideal location for the egt probe install?
Sean
