Old 01-16-2006, 01:55 PM   #1
sic///M
Bumper bolts R SEIZED
I need help. there the torx TX-55s. not budging at all
sic///M is offline   Reply With Quote
Old 01-16-2006, 02:21 PM   #2
I broke one of those el-cheapo torx bits from crappy tire cuz mines were pretty rusted too. For the back of the car, I had to undo the bumper shock bolts and take it off as one unit. Then after cut the bolt outta the shock. For the front it didnt have a bumper cover, so i drilled into the rebar and undid the bumper shocks from there... haha, hope this helps ya dude
Old 01-16-2006, 03:41 PM   #3
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Lots and lots of penetrating oil. A good quality torx bit (min 3/8 drive) and a strong bar. Put all your weight into pushing the bit into the bolt, then try to turn the bar. Sometimes easier with two people if you are a weakling
Good luck.
Old 01-16-2006, 06:27 PM   #4
sic///M
1 rachet + 1 breaker bar and counting
Old 01-16-2006, 06:37 PM   #5
King Luis
The King.
King Luis's Avatar
Send a message via MSN to King Luis
you know from experience right?
hahahaha j/k
2004 Silver Gray M3
Mods: Dice Unit, EAS Angel Eyes, Painted Reflectors, CSL Diffuser, Smoked Corners, PSS10s, 15mm Front and 10mm Rear Spacers.
King Luis is online now   Reply With Quote
Old 01-16-2006, 07:30 PM   #6
static
static's Avatar
from experience of removing rusty honda rear swaybar bolts
lots of WD-40 and leave soaked in it for a couple of days.
Then, the bolt head will probably strip from rust, don't despair, go get locking pliers (i think the proper name is vise-grips or something) and use it to get a good grip on the bolt.
That should help
Alex
static is offline   Reply With Quote
Old 01-16-2006, 07:33 PM   #7
sic///M
oh, can u remove the bumper cover (plastics) prior? how?
Old 01-16-2006, 08:33 PM   #8
Axxe
Axxe's Avatar
hahahaha j/k
Yeah, you got that right. I break so many strong bars (without cheaters) the folks at Canadian tire know me by first name "Oh **** it's Tom coming again, get a 1/2 drive strongbar and a couple extensions."
That's service
And if all fails (you strip the mofo out) you need to use a damaged bolt remover. Be patient, these things work very well if you use them properly.
Old 01-16-2006, 10:14 PM   #9
umm... if memory serves me correctly, first you remove the bumper trims, the black parts, be careful to not break the tabs, and the back bumper has two mini torx screws, umm actually for the back just take off the middle bumper strip, forget the sides, then theres those little plastic round pins underneath, pull out the middles, carefully, and the whole clip should come out...
