Old 03-07-2005, 10:39 PM   #1
mz3bo
No Heating in 1997 540I
Hello,
I got this major problem. The car is a 1997 540I and there is no heat at all when the car is at idle. This is killing me. However, when I rev the car up to 1500 rpm while standing still, I start to get some heat out of the vents. If I don't rev the car while waiting at a red light, the blowing air is dead Cold ... Once I am driving the car, the heat is back. No problem on highways...
Can this be the Water pump going weak ? The belt that drive the pump have been replaced not long ago.
Cheers.
Bo
mz3bo is offline   Reply With Quote
Old 03-08-2005, 06:05 PM   #2
BMVV
Does the tempature guage indicate normal, center, when the car is warmed up?
BMVV is offline   Reply With Quote
Old 03-08-2005, 06:14 PM   #3
mz3bo
The temperature indicate a normal operating temp (in the middle) in all situations.
Old 03-08-2005, 07:02 PM   #4
Gamite
Gamite's Avatar
I'm not sure how E39's are, but in E34's we have a heater core, in which the coolant flows through to heat up air. On E34's this gets seized up, maybe you guys have the same problem?
www.gamite.net
Old 03-08-2005, 09:14 PM   #5
raffa
Your heater core may be restricted, do the coolant system flush it might help. If possible reverse flush the heater core (look to see what is coming out of it, sludge,...). This is the cheapest "repair" that you can perform on the cooling system. You may also have much biger problems.
P.S. Price on heater core (part only) is about $300 if I remember correctly.
raffa is offline   Reply With Quote
Old 03-14-2005, 09:41 AM   #6
mz3bo
Someone told me (dealer) that it is 90% chance that the secondary water pump (V8 cars) is faulty. Does that sound normal to you ?
Old 03-16-2005, 09:17 PM   #7
raffa
Just check if auxilary water pump (electric) is working and you will know if they were right.
Old 03-16-2005, 11:18 PM   #8
mz3bo
And where is the auxiliary water pump ?
