Pretty easy to install, it will probably take 10-15 minutes of your time.
- One torx screw to remove so you can slide the instrument cluster out
- Unhook a plug at the back to remove cluster completely
- A couple of torx screws to remove at the back of the cluster to separate the front piece
- The rings already have adhesive so you just place it on the cluster in the desired position and you're done.
Other gauge rings don't come with adhesive and so you have to mess around with glue and then tie the rings up until they dry.. etc... These ones you just stick on and it doesn't dry up (the adhesive is like Play-Doh) so you have plenty of time to adjust and align until you're satisfied.
