Old 11-12-2004, 12:41 AM   #1
BMW325BMW
Commando
BMW325BMW's Avatar
how to change brake lines
K guys... really need your help on this one. I have to change the metal brake lines on the rear of my e30... the only real, major problem is, i dont know how. I have also come to realize that Hanes manuals suck. If anyone can point me in the direction of a website that shows a detailed step by step process on how to do this, it would be greatly appreciated. thanx
BMW325BMW is offline   Reply With Quote
Old 11-12-2004, 12:56 AM   #2
Eurostyle
Eurostyle's Avatar
My best advice is DONT! The brakes is not something you want to fu#k with, and old rusty lines can be a nightmare! If you start braking or stripping them you will end up needing more parts such as calipers or other lines. And in case you do get it, you still need to bleed the brakes, which again brings you to the calipers where you run into potential problems with the bleeder screws...So if you want to save youself a lot of time and agravation, get it done by someone, and start with some easyer jobs....
Old 11-12-2004, 01:11 AM   #3
BMW325BMW
Commando
BMW325BMW's Avatar
i've done all the easy stuff already... the calipers are new, and the flex hose's are new... now all i want to do the metal line because i broke one changing the flex hose, so might as well do both... also would you happen to know the thread pitch?
Old 11-12-2004, 01:19 AM   #4
Jordan
Why do you "have" to replace the lines? Are they rusted out? Leaking? What?
If you do replace them keep in mind that you cannot buy the lines new from the dealer preshapped. You can order the line with fittings on each end, but it will be a straight section of line of the proper length (if you bend it perfectly) and you will have to bend it yourself.
Your best bet is to find a donor car to steal good lines off of.
Old 11-12-2004, 01:19 AM   #5
Eurostyle
Eurostyle's Avatar
ok, is see you already ran into the problem i was talking about
Should be easyer from now on! Sorry, dont remember what the tread was...
Old 11-12-2004, 11:25 AM   #6
BMW325BMW
Commando
BMW325BMW's Avatar
thats the best news about it that i have heard... "it should get easier" i hope so, cause without brakes on the car, its alot easier to run it into a wall.
Old 11-12-2004, 12:21 PM   #7
M50E30
www.bmwclub.ca
M50E30's Avatar
Pick up some stainless braided lines.......you should be able to find a full kit for $160-$190.
M50E30 is offline   Reply With Quote
Old 11-12-2004, 12:49 PM   #8
BS87
Yeah, if you've got the rubber lines off to fix the metal one your broke, its worth it to throw some SS ones on there.
BS87 is offline   Reply With Quote
Old 11-12-2004, 04:08 PM   #9
Boris The Blade
I changed all my brake lines and it was a BIATCH!!! Get a line wrench too.
I busted a brake line in the rear and when i went to change it I found that everything was seized. they suck and I'll never do it again!!!
John!
Boris The Blade is offline   Reply With Quote
Old 11-15-2004, 04:01 AM   #10
Seriously, changing the line is a lot of work. I had the rear end out of my car (subframe and all) and got a line from a donor car. It was pretty simple, but still a huge PITA. Connecting the line at the master cylinder was hard, and I broke one small line coming out of the tblock. That wasn't too bad, I just bought a line bender and a bit of line and bent it up myself.
Good luck.
everlast is online now   Reply With Quote
