Old 08-18-2002, 08:51 AM   #1
e34biturbo
e34biturbo's Avatar
A diamond in the rough..making of a fast turbo E30 converticle
All components have been gathered and stored.......turbo, turbo manifold, wastegate, oil cooler, blow off valve, boost controller, and of course stand alone engine management system.....we will pull the engine this week...
e34biturbo is offline   Reply With Quote
Old 08-19-2002, 02:22 AM   #2
Let us know how it goes! I am starting a turbo E30 project as well and can use all the info I can get! So far I have the turbo, manifold, and a 524TD crank....
Old 08-19-2002, 08:50 AM   #3
e34biturbo
e34biturbo's Avatar
will the 524td crank mount without modifications?
I have been hearing different folks suggest i use this crank but never state if it is a direct fit...or what type od modifications would be needed if any....
Old 08-20-2002, 02:28 AM   #4
I guess there is only one way to find out for sure...try it, if it does not fit, make it fit!!! The manifold needs to be modified for sure...it does not bolt right on
