Old 04-02-2004, 04:41 AM   #1
crusher
OMGHI2U2
crusher's Avatar
Question suspension options for the m coupe
hey guys..
its either a set of mz rims or lower the coupe. Just getting some ideas on what are good setup out there and if you already done suspension work on your coupe what are you using? and how much/where did you get it would be great too.
H&R+Bilstien ?
I don't think i need coils since i'm not going to be doing much tracking or driving school. I just want to lower the ride height a bit to kill that nasty wheel well gap hehe
what do you guys think? btw, if I get another set of mz3 rims i can put my 99% summer tires on it.
Jeff
2013 Ford Focus SE
2011 Lincoln MKT
2003 Escalade 8 Seater of Fun - 251k and still running
Sold/Traded-in
2006 M5
2003 M3
2003 Civic Si
2000 M Coupe
1999 M3
1999 323i
Old 04-02-2004, 04:46 AM   #2
Quack
Wheelman
Quack's Avatar
if you get a set of summer rims get a larger rim, maybe a 2 piece rim, than drop it 1-1.5 inches
Old 04-07-2004, 05:26 PM   #3
97 Z3 2.8
Yep, H&R Bilstein is a good combo. Beware of the negative camber associated with lowering a semi trailing arm rear suspension. It gets excessive.
I've got Eiback Prokits which actually dropped the rear more than the front (or it certainly looked that way). To solve this I picked up a set of spring pads from the Stealer for 12 bucks each. (10mm pads I believe). It does raise the butt a bit, but mine seemed uneven, and it really helped the straight line tracking as well as the coil bind I was experiencing.
97 Z3 2.8 is offline   Reply With Quote
Old 04-07-2004, 06:08 PM   #4
crusher
OMGHI2U2
crusher's Avatar
thanks for the info. i need to get that ride height lowered atleast 1/2 or 1 inc and then get the alignment.
